builtone wrote:Is this a good pipe for a jet and 150 upgrade for 125 SM? I'm also going to change the sprockets and I'm curious what might be good for San Francisco with the hills and all.
DAVID THOMPSON wrote:i am running a 52 rear in place of the 49 ori
on my rt125 and it was a big improvement
here in my hilly town
in sf i mite go 54 or 56 but it will kill top speed on a freeway
my top is about 68mph with the 52
so 52 is ok and it runs sweet up to 65 then the rpm's get a bit high
DAVID THOMPSON wrote:it is the stock one for the SX and i used a adaptor made from the center
of the 49 tooth as it is not offset for the alloy wheel like the 49 tooth
This will make the bike perform better at speeds up to about 70mph
And give you better pulling power on hills at 55 and 60
It steals some top end but this bike is only 300 LB and much too
Light to be going over 65mph any way
GETTING 68 TO 70 ON TRIPS IN AUG 2004 WITH 16 /52 16/49 WAS ABOUT 73 75 MPG
DAVID THOMPSON wrote:builtone
i would not worry about a pipe till the motor is broke in
if your going to be using it on roads posted 55 mph or less
52 tooth will make it run nice but a 54 will turn it into a hill
climber but top end will suffer
in SF i would go for the 54 tooth and stay off freeways posted over
55mph
with a 54 this thing will EAT most street 250's a new ass up to 60 mph
unless the have had the same mods
but don't rev it up tooo hard till its got at least 3000 miles on it
because if you blow it at high rpm i will here the noise from here in WV
and also hear the flying parts landing on my roof
DAVID THOMPSON wrote:on the SX 52 is stock but rear wheel is an 18 so a 54 would
make it pull better but 56 mite make it a bit slow on the
freeway
with the SX you will have to be the expermenter
