droy wrote:If you haven't done it already replace all the rubber hoses, given the age. The hoses that run up to the oil take will split and leak oil on your rear tire which can make cornering very interesting. Experience talking here!! I have two of these Skorpions running and two in pieces as projects.
Doug
Thanks, Doug. Will do. The only line that "looks" bad is the breather line. I was just wondering if a crankcase split line leak was likely. I wouldn't think so, knowing Yamaha, but still.. Maybe I didn't do a good enough job of cleaning when I changed the oil and filter.
Speaking of that, once I had it running, I backed off the top screw on the oil filter housing, and a little oil oozed around the screw. I would have thought there would be a *lot* ? It's just weird, not having an oil pressure light/gauge, etc.
edit for typo..
