Rubber tubes in the barrell and head
Postby cameronda » Sun Jul 19, 2015 5:16 am
G'day
I am replacing the rubber tubes that go in the cylinder and cylinder head
The instructions are all in German
Basically I wet the tubes and then insert and trim
I have copied the German text (to the best of my ability)
Fur jede bohrungseinheit wird ein geschlitztes und ein geschlossenes rohrchen verwendet. zunachst sollten die rohrchen mit einer Wasser Spulmittelmischung befeuchtet werden. nun wird das geschlitzte Rohrchen in die bohrungen eingefuhrt, und danach das geschlossene. Den sich ergebenden schlitz wie Beim original vorher zum zylinder drehen, damit er von auben nicht sichtbar ist. Benotigt wied eventuell nu rein Gummihammer.
Gegebenen Falls sollten die Enden noch gleichmabig ca.5mm vor der Kuhlrippe oben und unten abgeschnitten warden
Am I correct?
Thanks in advance
Dave
cameronda
Re: Rubber tubes in the barrell and head
Postby therealche » Sun Jul 19, 2015 7:44 pm
That looks like it... wet them, make sure the slot is at the back and tap with a rubber mallet , then if needed trim to leave 5mm extra
therealche
Postby cameronda » Mon Jul 20, 2015 4:41 am
That is how I get it
cameronda
Postby MichaelTorre » Thu Jul 30, 2015 9:31 pm
Don't do what I did.
I did not wet them......
My duh.....
A lot of extra sweat.
M-
MichaelTorre
Postby cameronda » Fri Jul 31, 2015 4:25 pm
G'day
How wet do they have to get?
Can you wet them in place?
How fast do you need to be installing them?
The head I think I will wet them in the head then fit head to bike.
The cylinder in on the engine and the engine is in the frame
cameronda
Postby DAVID THOMPSON » Fri Jul 31, 2015 8:14 pm
a tad of dish soap in the water should help
a bit
