Gear Selector Centreing Spring Broken
Postby Shiny » Sun Mar 06, 2016 4:02 pm
My 2005 MZ1000ST has broken spring. Can I assume this is a part common to other makes? Any help appreciated. Unfortunately the broken off part appears to have dropped into the sump so, until I retrieve it I cannot determine the style.
Shiny
Re: Gear Selector Centreing Spring Broken
Postby Shiny » Sun Mar 06, 2016 9:36 pm
Thanks for the link to the parts book. I'm having a local spring manufacturer make up 2. They will be a bigger guage so should last (bike has 47,000 klms).
If anyone needs one I can supply.
Shiny
Postby MJ310 » Sat Mar 12, 2016 12:36 pm
Mine has gone as well, seems to be a common fault, bike works fine and I can select gears but I have to be slow and deliberate. One day I will open it up and have a look. Take a picture and post it.
MJ310
Postby Shiny » Sun Mar 13, 2016 2:54 pm
MZ Spring.pdf
(102.7 KiB) Downloaded 784 times
Hi MJ,
Graham's confirm they have these in stock for a very reasonable 6 - 7 pounds. A huge saving on the $350 my local spring manufacturer wanted.
Here's the part you need;
33 3547306000 Rückholfeder für
Schaltwelle
return spring for shifter.
I found the broken piece in the sump. Tried retrieving through the sump plug hole with a magnet but missed it. Ended up removing the sump (Radiators and exhaust need to come off) which revealed absolutely no metallic material or sludge at all. Nice to know.
To get at the mechanism you need to remove the clutch. I made a special tool from a socket and used a rattle gun to remove the clutch nut/collar.
Shiny
Postby boilermaker » Tue Mar 15, 2016 7:00 am
My gear return spring also broke at around 30,000 m. Grahams supplied a new one and I made up a clutch tool from an old socket. Thank god the selector operating system is outside the gearbox. Although the box on this machine can be removed in one piece if I remember rightly.
boilermaker
Postby MJ310 » Fri Mar 18, 2016 3:05 pm
Can you tell me what you did to make the clutch tool or show a picture, I will buy a spring next time I am in Taunton.
MJ310
Postby Shiny » Fri Mar 18, 2016 5:30 pm
33mm I'd is a critical measurement. Used a grinder and a miniature belt sander followed by hand file to finish. Hope this helps.
Shiny
Postby MJ310 » Sat Mar 19, 2016 2:20 am
Thanks Shiny, I don't have access to a grinder at the moment but I might know someone who has. How thick are the teeth?
MJ310
Postby DAVID THOMPSON » Sat Mar 19, 2016 7:08 pm
grind it slow so you do not get too hot and ruin the temper
Postby Shiny » Sat Mar 19, 2016 7:29 pm
The posts are approx 5mm wide with approx 20mm between them. Davids right, too much heat might result in the dogs failing due to the rapid power delivered by the rattle gun. It really is worth taking your time, trial fitting as you go.
Shiny
Postby billr » Mon Mar 21, 2016 6:07 pm
That looks amazingly like a bicycle tool I used to have...don't have that bike any longer( and no idea where the tool wound up...it ain't in the box)
Park 4-prong freewheel tool
That one is only 32mm inside diameter, though.
BillR
billr
Postby Shiny » Thu Mar 24, 2016 11:20 pm
I've been reassembling the clutch following installation of the new gear selector centering spring. I've found that after doing up the centre clutch nut with the rattle gun, it's locked with the basket. On taking some pressure off by slightly unwinding the nut it free's the basket but still is binding.
Went ahead and assembled everything only to find the clutch lever is locked and not actuating the clutch release rod.
Anyone have any ideas? I didn't lock the clutch lever to the handlebar as I didn't think it nessecary.
Not a good day at the office, still great riding weather, so leaving it for the night.
Appreciate any advice.
Shiny
Postby Shiny » Thu Apr 14, 2016 9:51 pm
Ha! that old extra thin gear behind the main cog driving the clutch not aligned trick.
I don't have the special tool shown in the manual so carefully used a screwdriver to move it into line.
Not sure if this will work as I don't understand the purpose of this thin gear.
Can anyone enlighten me?
Shiny
Postby MJ310 » Fri Apr 15, 2016 3:03 am
Can't help I'm afraid but it's all useful stuff for when I tackle mine. Keep us informed on what you find.
MJ310
Postby Shiny » Sun Aug 28, 2016 8:57 pm
Well, after all the nervous-nous around the pretensioned gear behind the clutch cog, the bikes running fine. What a difference a new set of spark plugs has made.
Shiny
Return to 1000S
Users browsing this forum: Bing [Bot] and 6 guests
