Re connect clutch cable
Postby Joshua_m » Sat Oct 15, 2016 7:32 am
Hello my fellow Mzriders, im hoping someone here wil be able to help me out, i had to disconnect my clutch cable to drop the engine now i got my engine back from the shop and i put it back in and re connected everything but reconnecting the clutch cable is giving me alot of problems. When i took the cable off i was able to slide it off of the little arm on the engine but no matter what i try im unable to reconnect it to the clutch arm mechanism. Thank you for your time and good luck.
Joshua_m
Re: Re connect clutch cable
Postby DAVID THOMPSON » Sat Oct 15, 2016 11:31 am
which mz size and model are you working on
2 stroke or 4 stroke
Postby Joshua_m » Sat Oct 15, 2016 4:25 pm
2002 MZ SM 125
Joshua_m
Postby DAVID THOMPSON » Sat Oct 15, 2016 4:46 pm
will send a note with pictures some time sunday afternoon about the clutch adjustment
need to round up my tablet with a good camera and the shop manual
there is an adjustment on the clutch basket that may have you fouled up
Postby DAVID THOMPSON » Sun Oct 16, 2016 10:47 am
pictures click on them to see bigger click 2 times makes them very big
.. pictures came out in reverse order to what i wanted 4321 4 is at top
1 tighten up adjuster nut at handlebar
so cable has full slack
pic 2 install cable at transmission may have to twist lever there toward front of bike
if it will not go on check cable routing
3 shows inside adjustment be careful about the spring and ball bearing in the spot marked on picture
in red
it is the OIL PRESSURE REG
4 use a side cover gasket to make a storage board for side cover screws there different lengths
Postby Joshua_m » Sun Oct 16, 2016 12:26 pm
With your excellent instruction i was able to re connect the cable in just 10 minutes thank you for taking the time out of your day to assist me. I wish you good luck with everything and god bless.
Joshua_m
Postby DAVID THOMPSON » Sun Oct 16, 2016 9:20 pm
thanks for the thumbs up..
coming up NOV 8th i have been the mod here 9 years
its been fun
except for the tons of spam we get but that seldom happens any more
what helps is when i see someone doing it in real time and erase him faster than he can post it :smt023
Return to 125 cc
Users browsing this forum: No registered users and 100 guests
