gear lever availibility
Re: gear lever availibility
Postby seattleMZ » Sun Jul 23, 2017 12:35 pm
So far so good, 300+ miles 200+ shifts and still working. I switched out the 2 nuts and lock washers for ss nylon lockers yesterday. Still researching a replacement shifter. Our local motorcycle salvage yard closed after over 40years in business so it's going to be more difficult to do when you can't physically examine other bikes shifters . I've contacted several shifter makers for specs, but they havn't responded.
--Michael
seattleMZ
Postby rodge70 » Sun Jul 23, 2017 4:06 pm
had mine welded and braced but that snapped again a year or so later so machined up a new rear part of the lever and bolted the front haf of the mz one to it,will try and put a pic up of it later
whoops just read all the posts and see i have already posted the above pic,will make an effort with the updated version :oops:
Fingers crossed sorry for crap pic not used bike in months,had a lump of ally lying around and shaped to replace rear of old lever then bolted the front half of lever to ally,cable tie was for positioning it,never got round to cutting it off
i tried to turn this pic so it could be seen proper but it just refuses to turn
DAVE site mod
rodge70
Postby seattleMZ » Thu Jul 27, 2017 11:00 am
That fix looks strong. I was thinking the exact same design. I lost the last 90% of the shifter so I have to fab the toe piece. One of problems with the stock shifter is the frame bolt sleeve needs to be longer and a bearing.
--Michael
seattleMZ
Postby handsomejackuk » Thu Jul 27, 2017 3:36 pm
rodge, do you ever get over the other side of the bridge.. i thinking of going to cmc superbikes on sunday there a stunt show there. if you fancied coming over weather permitting...
Al.
handsomejackuk
Postby den » Fri Jul 28, 2017 6:14 am
i got spare one
den
Postby seattleMZ » Fri Jul 28, 2017 12:09 pm
@den..are you offering to sell your spare shifter?
--Michael
seattleMZ
Postby den » Sat Jul 29, 2017 12:16 pm
seattleMZ wrote:@den..are you offering to sell your spare shifter?
--Michael
sure if you need it, I paid £30 for it two years ago, saw it as a spare too good to miss up but if you need it because yours is broken then yes,
den
Postby seattleMZ » Sat Jul 29, 2017 1:07 pm
I think shipping to the USA might be a huge hassle for you?
==Michael
seattleMZ
Postby rodge70 » Sat Jul 29, 2017 2:36 pm
Hi Al,not very often,been to abergavenny a few times, as for this weekend busy welding mates frame and making up sprockets and stuff for mower as 12 hour race is looming on the horizon a bit to quickly :D
rodge70
Postby den » Sun Jul 30, 2017 10:34 am
seattleMZ wrote:I think shipping to the USA might be a huge hassle for you?
==Michael
not really, post is post, maybe expensive, would you like me to find out how much?.will need zip
den
Postby seattleMZ » Mon Jul 31, 2017 5:11 pm
Sure it's 98177
seattleMZ
Postby seattleMZ » Wed Aug 30, 2017 11:54 pm
Ok I went a different direction and pulled the linkage and stock shift lever. I went direct to the transmission with this
Sunline Alloy Shift Lever
Color- Alloy, Size- --
SKU#312979
http://www.motorcycle-superstore.com/81 ... hift-lever
I chose the 2001 yamaha YZ250
So far it works like a charm...I'm ordering a spare.
This is my own photo.
The shift pattern is the same . The main difference is there's weight hanging on the transmission spline ( not much level is super light) You also have the possibility of damaging the spline if you jump on the lever or crash. The tip folds up on this lever making it safer. If you ride a dirt bike this feels exactly like that and looks much cleaner. Many raptor riders switch direct levers and I didn't find anything that stopped me from making the switch.
Update 09/06/2017
A full week of riding and no problems with the shift lever.
seattleMZ
Postby DAVID THOMPSON » Thu Aug 31, 2017 11:54 am
this makes shift pattern backwards ?????
Postby breakwellmz » Fri Sep 01, 2017 2:23 am
Nice one SeatleMZ but what model Honda is it?
No it won`t David.
Postby DAVID THOMPSON » Fri Sep 01, 2017 11:35 am
if it goes on a mz traveller
i think it will
the foot peg is farther back
Users browsing this forum: Google [Bot] and 15 guests
