handsomejackuk wrote:bike has a bsm future exhaust system thats it... I did the valve clearances a while ago... bike runs and doesnt use any oil... i leave it as it is then... i just wondered if it was easy to remove the head without taking the engine out ?
dandywarhol wrote:https://www.off-the-road.de/en/home/ for the slide mod
I fitted a pair of Raptor 33mm carbs to my 660 - probably no extra power to speak of but much more responsive. 43 hp at the wheel
dandywarhol wrote:I've still got a CP 727 kit with Carillo rod, Hotcams3, Kibblewhite guides & springs, 2 x 33 Keihins, Projection Components downpipes, Ignitech CDI and a lower 5th gear engine to build - other projects getting in the way......................
edfmaniac wrote:dandywarhol wrote:I've still got a CP 727 kit with Carillo rod, Hotcams3, Kibblewhite guides & springs, 2 x 33 Keihins, Projection Components downpipes, Ignitech CDI and a lower 5th gear engine to build - other projects getting in the way......................
Probably want to look at a billet clutch basket if all that stuff works well together. You gonna do a valve job too? My guy ended up installing +1mm stainless valves on my head. Can't remember why but he only charged me for the extra cost of the valves over the standard labor/parts cost.
Users browsing this forum: No registered users and 117 guests
