Just for fun I'll let you fellas have a go at working it out before I tell you what I did with my motor? I'll post up photos in 2 or 3 days in any case.
Mark.
dandywarhol wrote:Interesting that if you google 660 decompressor failure, by far the majority of failures are on quads. Could there be a significance that quads are more liable to over rev in low gear on the overrun - no limiter will do anything about that
edfmaniac wrote:dandywarhol wrote:Interesting that if you google 660 decompressor failure, by far the majority of failures are on quads. Could there be a significance that quads are more liable to over rev in low gear on the overrun - no limiter will do anything about that
I would assume that has more to do with the number of units in circulation and the fact that ATV guys tend to abuse the hell out of their quads. Not sure if the last part of your statement is a question or not. Removing the projectiles that fly through the motor case at high rpm will prevent said projectiles from doing so.
