BING 84 on ETZ 251 - low power
Postby JurassMz » Mon Jun 01, 2015 11:34 pm
Hello,
I have Bing 84 on my ETZ 251 purchased from ost2rad.com. This is my problem: the power of the engine is quite low at begining (about 1500rpm) so it is problem to drive off in the hill for example (I must use clutch tooo much). After that in the middle RPM it have good draw I think. But at the higher RPM, lets say about 4800, it starts to be weak. For example at 4. transmission grade it can't achieve more then 5000RPM on the horizontal road }which means less then 90km/h). On 5. transmission grade it doesn't accelarating more then 4300rpm (again 90km/h), then veeery slowly, maximally to 4800rpm. Lets say my maximally speed is 90km/h and thats too low.
I have gear with 20 sprockets.
Can you help?
JurassMz
Re: BING 84 on ETZ 251 - low power
Postby DAVID THOMPSON » Tue Jun 02, 2015 11:40 am
it may be geared too tall
and exhaust pipes other than stock can cause lots of problems
Postby JurassMz » Thu Jun 04, 2015 3:39 am
How do you mean - too tall - I have written there is secondary gear with 20 sprockets (21 sprockets is on original Mz).
What do you mean by stock exhaust? Do you mean original exhaust made in Germany (not available yet) or just original exhaust? If so there is original new exhaust made in Hungary although for MZ ETZ 250 - it may be same as for 251 just a little bit longer.
JurassMz
Postby vicar » Thu Jun 04, 2015 8:42 am
Your gearing is ok,
what exhaust do you have fitted is it clean internaly, they can get full of oily sludge and hard burnt on carbon , is the exhaust port full of hard carbon . The exhaust plays a major part in making power if its a bit blocked up you get the symptoms you have listed.
Etz s have little or no power below 3000 rpm and it tails off at 6000 rpm so its normal to use some revs and clutch slip to get going on a hill.
If the needle in the carb is on a high clip setting its a bit weak and will need lots of revs to get going, if its to rich it will pull well at low / middle revs and get wooly and refuse to rev out.
Try this
Make dam sure the air filter is clean with no blockages
Confirm that the fuel tap/pipe is flowing freely
clean the exhaust take it off. block one end and fill it with a strong mixture of caustic soda and leave overnight to disolve the carbon.give it a good rinse out with water
check the exhaust port for carbon deposits
Set the carb up for YOUR BIKE !!!! that carb can be fitted to a number of two strokes and they will all have different jet sizes and needles, needle positions.
Is the bore piston rings worn out
vicar
Postby JurassMz » Tue Jun 30, 2015 9:27 am
-DONE, filter is new and clean
-DONE, fuel if flowing absolutellly freely
-DONE, exhaust burned with gas and then cleaned with NaOH
-DONE, no carbon there
-DONE, carb us setted up in the best way
-DONE, piston rings are new couse I have engine 5000km after General Repair.
However all problems persist. :|
JurassMz
Postby DAVID THOMPSON » Tue Jun 30, 2015 10:02 pm
this means the ignition system if probable screwed up
just my experience with old BMW magneto fired bikes
6 volt point and coil systems suck and 12 volt ones are not much better
these things are just big mopeds 250 cc is good for 55 mph over that is pushing it to hard for it to last very long
Postby therealche » Wed Jul 01, 2015 12:06 pm
DAVID THOMPSON wrote:these things are just big mopeds 250 cc is good for 55 mph over that is pushing it to hard for it to last very long
Rubbish! I ran TS250/1s for many years. They were happy at 70mph day in day out. Top speed of an ETZ 251 is a shade under 90mph.
Come across quite a few stories of problems with the Bings being sold these days. I think they are being made in China these days and the quality control seems iffy to say the least.
therealche
Postby DAVID THOMPSON » Wed Jul 01, 2015 1:47 pm
i am used to the jap 2 smokers from the 1970's
and a 250cc at 70 mph was usually a hole in the piston in short order
the ones with auto oilers would do better than most
but till the water cooled units came out they were not very good
i knew about MZ but there never seemed to be any one selling them
till the 4 strokes arrived
Postby fotonord » Wed May 02, 2018 5:10 am
Hi
Is that the cheap version og their Bing Carburetor you have choosen ( Chinese Copy )or the Expensive version
the chinese copies dont run very good , most of them dont run at all ;-)
fotonord
Postby Puffs » Wed May 02, 2018 11:24 am
Hi!
Why would that be? I mean, why would a bike not run, or run poorly, with a Chinese carb, after you have properly adjusted it (jets, cut-out, needle & guide)?
Carburettors are pretty simple, but you do have to adjust them properly.
Postby dirtsurfer » Wed May 02, 2018 9:53 pm
DAVID THOMPSON wrote:i am used to the jap 2 smokers from the 1970's
I rode,service,repaired, raced, tweaked and obsessed on 2 stroke, singles,twins and triples for years up to a year or two before water cooling became de rigueur and saw a few nip ups (fixed with honing) but rarely a hole in the piston. Full on seizures were usually explained by lack of lubrication rather than overheating. I'm not arguing simply comparing my own experience.
I too, had heard of MZ's but they we're considered to be "communist crap" by the Japanese two stroke biased auto trade community that I grew up in. Unfortunately the MZ's were tarred with the same brush as M series Urals that arrived in the early to mid '70's.
MZochist
dirtsurfer
Postby dirtsurfer » Wed May 02, 2018 10:47 pm
:D I just realized the original post was 3 years ago.
@JurassMZ has probably sold his 251 and bought a Grom by now
MZochist
dirtsurfer
Postby Puffs » Thu May 03, 2018 4:16 am
Aja, but we can happily take off where it was left. Zombie threads never die!
Yes, MZ's were (and sometimes still are) seen with prejudiced eyes. My opinion on my ETZ251 is that it is actually constructed very effectively, and made well. It is not a Ducati, but it is, in my opinion, a well made cheap bike, which rides well & is build to last. And with sufficient effort you can make it go like stink. Why JurassMZ's bike didn't I don't know, but my guess is that something was wrong.
Prejudice is why I reacted to the comment on the Chinese carbs. My experience with those is limited to just 1, but that has worked fine (for more than 30 000 km by now). It's just that if you buy a carburettor off the shelf, any make, you have to adjust it to the bike you fit it to. The manufacturer doesn't know beforehand what bike it'll be fitted it on, and the generic jetting he put in may not work for your bike.
Btw, I actually still own a '68 CZ 980 (which I've had from the early 70's on!). It's a 250cc that does a claimed 28hp, so quite a bit more than a standard MZ250. Somewhere along the line I fitted a 34mm Bing 54 to it, but that was probably German. And in the 70's I've had & raced (MX, not road) several other 2 strokes, including Kreidler's, KTM(Sachs)'s & YZ's, and never have I had a hole in my piston (which I understand would be an indication of a main jet that's way too small). Indeed, piston lubrication can be an issue, and the increased friction can lead to local overheating --> expansion & a nip up, as you call it. In my opinion it all hangs together.
Now if ever I knew what a Grom was...
Postby DAVID THOMPSON » Thu May 03, 2018 10:25 am
GROM = little town bike by Honda selling really well in the usa to replace all the honda trail 70's that are worn out
Postby Blurredman » Fri May 04, 2018 4:31 am
Very true.
A replacement carburettor for a 70's vespa, came with jets which were far too small and it ran awfully. Put in it the jets from the original carb and the user can make full use of the engine/carburettor characteristics!
1987 MZ ETZ300 - 40,000 miles
Users browsing this forum: No registered users and 38 guests
