Puffs wrote:With the pilot 2½ turn open & the bypass 3½ turn open, my 251 idles to my liking at around 1650 RPM. That's on the mechanical rev counter, which I'm not sure is very accurate. Haynes specify 1200 RPM for it.
Edit: this thread caused me to have a look at the idling of my ETZ251, which has a BVF 30 N 3-1. By closing the bypass a little further it does idle slower, and it can idle at around the 850 RPM you mention, in a stable fashion (doesn't miss a beat). But I don't really like it, the pick-up on the throttle is then sluggish, and most importantly: the entire engine vibrates up & down in the rubber. So that must load/bend the exhaust. I went back to about 1500 RPM.
