homebrew123 wrote:This is the set up for the early seat/panel/tank fixing, this is one that I made up out of a furniture fixing m6 short sleeve nut and an aluminium large load spreading washer approx 25mm OD, 4-6mm thick with an m8 hole in the middle and a countersink, but if you can find them, the original sort are a similar size with a squared recess for the head not a countersink, but to be honest the ones I use work just as good if not better than the originals. It was only the first Baghiras and Mastiffs that were made that had this set up, and the fuel tanks are normally a strange green colour not black like the later ones, also these tanks were not made by Acerbis, unlike the later ones that are marked Acerbis underneath, the old ones were made by a German company in Hamburg. Hope all this helps, and if you use the seat fastener set up, make another couple of new 20mm long m6 studs to screw in the tank bushes, if you can get the old ones out that is. I have just had to drill the studs out of the brass bush on both sides of a tank to be able to use it again, because the sleeve nuts were seized solid and the bush was just turning in the tank recess when I tried to move it, but not loose enough to pull out at all. So I drilled the studs out, picked out all of the old thread left inside them, and ran a m6 tap back down the bushes to clean the thread up again and screwed 2 new studs in as tight as I could because it still started to turn in the tank again, and used the fasteners pictured to finish the job, and it works and looks perfect, probably better than the later Dzus fasteners lol
homebrew123 wrote:Hi, sounds like you doing a thorough job on it, as a matter of interest where did you get the fork stanchions from and how much were they please.
cheers.
Jon.
breakwellmz wrote:The one going into the base of my seat through the mudguard got lost a long time ago (not surprisingly really)I drilled out the seat fitting and bonded in a length of M6 stainless studding. This is secured by a knurled M6 stainless hand-with a spring between it and the mudguard underside, works a treat!
Users browsing this forum: No registered users and 114 guests
