A bit cooler down your way though?parrbd wrote:Those gaskets are easy to break. Best to lay the bike on its side when installing. Yes it has been hot. I was out on the ETZ today looking for the stingray swamp swimming hole in Penrose forest. Did not find it so had to ride back dusty and sweaty.
parrbd wrote:I wonder if the gear lever off the DR (in the background) would fit?
Blurredman wrote:.....
In terms of locking the crank.. I use rope down the plug hole. This stops the piston getting to TDC so it locks.
Blurredman wrote:Just so you know, ETZ 251 and ETZ 250 have different length gear levers..
You'll obviously want the ETZ250 (?), which is the longer of the two.
Andy_C wrote:Re expansion pipes.
The short one (which seems to be the only one you can get) will fit to the standard bracket - you may need to bend it a little but it will fit, at least it did on mine.
Being a short pipe you will find that it robs the engine of what little low down torque that these engines have, instead of starting to pull at around 3500 RPM it will move it up about 1000RPM, it also robs some of the mid range, however you will find that the motor revs much more easily and you can exceed the red line (6500RPM?) easily - not much point as you do not get any more power.
Basically with these short pipes you have to be revving the motor pretty hard to maintain a decent pace.
My "solution" was to weld a 10" (or therabouts) long cylindrical section in the middle of the pipe, and as far as I can feel it now works at least as good as, if not better than the standard pipe - I'll post up a pic of the pipe sometime if anyone wants to see it.
Just thought you might find my experience useful.
dirtsurfer wrote:Blurredman wrote:Just so you know, ETZ 251 and ETZ 250 have different length gear levers..
You'll obviously want the ETZ250 (?), which is the longer of the two.![]()
I've ordered 250/251/301!?. I guess I'll find out if it fits when it arrives.
Puffs wrote:The problem fitting the bracket is that standard both connections are to the rear of the shock, while here the connection to the pipe is forward of the shock.
Dirtsurfer, do you know which clearance your new RAM piston has?
