Lithium Iron battery in the MZ1000s
Postby AJJohnson » Sat Jan 31, 2015 10:47 pm
The battery on the MZ reached the end of its lifespan last month. I decided to give a Battery Tender Lithium Iron battery a try. It is a BTL14A240C to be exact. After fighting the swollen gas tank :( and getting to the battery, it was surprising how much smaller & lighter the new battery is. Seems to crank the bike just fine though.
The LiFPO4 (lithium iron phosphate) battery is said to hold a charge longer and provide more cold cranking amps. We'll see how it works out. It ran about $105, so it wasn't too much more than a quality AGM battery. If I don't like how it performs in the MZ, it is small enough to serve duty in my 1972 BMW cafe racer. (It has a kick starter just in case.)
2007 Moto Guzzi Griso (my holy grail)
2005 MZ1000S
2002 Moto Guzzi Lemans
2001 Honda F4i
1998 Kawasaki ZX7r
1974 Moto Guzzi "Police" California
1972 Moto Guzzi Eldorado w/ Dnepr Sidecar
1972 BMW R75/5 Cafe Racer
AJJohnson
Re: Lithium Iron battery in the MZ1000s
Postby MJ310 » Fri Feb 06, 2015 4:09 am
AJ please keep us informed on your new battery, the MZ is a hard bike to start and needs a good strong battery, I just replaced mine with a high power yuasa so I am hoping for a good few years out of it but I will consider a LiFPO when it dies.
MJ310
Postby boilermaker » Tue Jul 21, 2015 11:12 am
Once again it is down to the "COLD CRANKING AMPS" of any battery that you fit to your machine . All modern machines seem to work at marginal cranking amps.
boilermaker
Postby MJ310 » Fri Jul 24, 2015 3:35 am
The only problem with LiFPO batteries is they don't like the cold.
MJ310
Postby AJJohnson » Tue Aug 04, 2015 12:53 am
MJ310 wrote:The only problem with LiFPO batteries is they don't like the cold.
Well, the Texas coast doesn't give me too many of those days to worry about. :D
I am quite pleased with how well the battery is holding up. I purchased a second one for a 2002 Moto Guzzi Lemans that I picked up as a project.
2005 MZ1000S
2001 Honda F4i
1998 Kawasaki ZX7r
AJJohnson
Postby AJJohnson » Mon Nov 23, 2015 9:28 pm
Hadn't started the MZ up in about 2 months and the temp was right around 50f. There was a bit of a drag, but the bike fired up. I am pleased with the LiFe battery and have had good luck with the one on my LeMans too.
2005 MZ1000S
2001 Honda F4i
1998 Kawasaki ZX7r
AJJohnson
Postby AJ-Johnson » Sun Jan 27, 2019 8:56 pm
Well, the Lithium Iron battery seems to be on it's last legs. I can't say that I treated it any different than any other battery. I have kept it on a battery tender at times. I got 4 years out of it, which I feel I would have got out of a good AGM battery. So, the next battery will be an AGM again.
AJ-Johnson
Postby arny » Mon Jan 28, 2019 3:38 pm
Lithium batteries can't be normally be used as a direct replacement for a lead-acid battery, they require different chargers.
They often survive long enough though, as in this case, but... under some circumstances they might get overcharged and protest in the form of an explosion... and when lithium batteries explode they are quite little napalm charges... :lol:
To sum it up, they can work in the place of lead-acids but they're not safe, more precisely, they can be quite dangerous!
To correctly use them in a vehicle originally equipped with lead-acid batteries, proper charge electronics should be fitted.
Arny
arny
Postby Puffs » Tue Jan 29, 2019 3:59 am
Postby AJ-Johnson » Wed Feb 20, 2019 7:44 pm
LiFe batteries (lithium Iron) are different than Lithium Ion (notice the lack of the R) batteries. They are not an fire / explosion hazard.
Read below. I reality, I don't think a AGM would have held up any better considering how I use the bike. I ride less than 30 times a year.
https://www.bikebandit.com/blog/tough-q ... -lead-acid
AJ-Johnson
Postby Puffs » Thu Feb 21, 2019 5:52 am
Postby arny » Sat Feb 23, 2019 8:09 pm
Yes, lithium-iron batteries may be somewhat different than other lithium-ion batteries, but nevertheless they do belong to the lithium-ion family.
However, all lithium-ion batteries require similar chargers, which are distinctly different than lead-acid battery chargers. Even if the lithium-ion battery type is not a fire or explosion hazard, that doesn't mean they can be charged by lead-acid chargers and stay healthy.
Arny
arny
Postby DAVID THOMPSON » Sat Feb 23, 2019 10:07 pm
be careful guys all the different types can be nasty
at times the old lead type can put off h and o and blow the hood off a car if over charging
Postby m4panther » Sun Feb 24, 2019 7:20 am
this is the battery you want to replace the OEM with. MZ specified a 200CCA this battery is 240. May your 0345 code never come back. https://www.yuasabatteries.com/battery/gyz16h
2001 Black Panther
2004 1000s
m4panther
Postby MJ310 » Mon Feb 25, 2019 6:07 am
Or a Yuasa YTX14H-BS, cheaper but has the same 240CCA power, that's what I use.
MJ310
Return to 1000S
Users browsing this forum: No registered users and 147 guests
