saxon tour idle speed/oil pressure
Postby pigeonboy97 » Wed Aug 07, 2019 6:25 am
hey folks. 1995 saxon 500 tour, idles at about 1100 rpm, sounds a little lopey, and once its warm, if I'm at a light with the clutch in or in neutral, the oil light will flicker on, but turn off upon revving. should oil pressure be low enough to trigger the oil light at idle?
pigeonboy97
Re: saxon tour idle speed/oil pressure
Postby DAVID THOMPSON » Wed Aug 07, 2019 9:33 am
should idle a little faster and i use 20w40 shell rotela oil
with fresh oil light should go out engine is dry sump most of the time most
of the oil is in the frame
read this
may help you make it run better
viewtopic.php?f=26&t=827&p=4620&hilit=sparkplug#p4620
Return to 500 cc
