Help - I have a slight coolent leak
Postby herbalist » Wed Aug 10, 2005 4:41 am
Hi people............
Just discovered this sight.
Have been an MZ owner for 1 week now.
Purchased a SM125 from new, and loving it sooooooooooooo much.
I have a quick question.
I have noticed a few drops of coolent under my bike and around the engine.
Its hard to say where it has come from,
Is this something to worry about, or is this normal......... bedding in period and all that.???????
Please help.
herbalist
Postby jbthumper » Wed Aug 10, 2005 5:03 am
welcome to the site!!
just my 2 cents worth
since it's new,then i would say it's the bedding in period...
btw,is it dripping???if it is,bring it back to the dealer...but if it's not...
just give your bike a gd wash, run it for a few days... and see if it still appears...and take note where it's from(if any)...
keep us posted!
cheers. :D
:smt033
jbthumper
Postby herbalist » Wed Aug 10, 2005 5:38 am
It has happened twice.
Both times after a ride while parked and cooling down.
First time was the 2nd day I had the bike, and was maybe 3 drops.
Then again the next day. But was maybe 10 drops.
Ihave since cleaned the blue crap off my engine, it has been twos days now and NO DRIPS......!!!!!
(wow thanks for the speedy response JB - think I will be on these forums quite a bit from now on)
herbalist
Postby jbthumper » Wed Aug 10, 2005 5:55 am
don't mention it. :-)
no more drips???that's great!!
just to be on the safe side,do check your coolant level when the bike's cold.
Ride safely!
:smt033
jbthumper
Postby herbalist » Wed Aug 10, 2005 6:00 am
Thanks again mate.
just noticed your "joined date" is my birthday.............!!!!
now thats a coincidence.............
herbalist
Postby herbalist » Wed Aug 10, 2005 10:28 am
Checked again,
Still the odd drip here and there, cant work out where its coming from.
Guess its back to the shop for me at the weekend.
Any other tips or advise would be very welcome.!!!!!!!!!!
herbalist
Postby jbthumper » Wed Aug 10, 2005 11:51 am
there are only two outlets for the coolant(not including leaky hoses of course)
one is from the overflow valve(near the radiator cap)...the hose is tied along the front engine mounting....
the other outlet is right under the engine,a bit to the right side.
this one doesn't usually leak on new bikes(any)...highly unlikely...
i think it's the cap that's giving you the problem...(just a guess)
anyway....since it's new...maybe you could ride it to your dealer and have them look at it...optimize the use of your warranty while you have it :-D
gd luck...!!
:smt033
jbthumper
water leak
Postby DAVID THOMPSON » Wed Aug 10, 2005 3:22 pm
see picture below
location 1 a hole on bottom of motor may weap some times
but if you get a lot here it may be a bad waterpump seal
there is a drain hole here to let water out if the pump seal fails
item 2 the over flow tube may get some here if system is too full
in very hot weather there is no catch tank like on a car
for a bunch of info on your bike go to the search page of the site
and do a search for "poster"
or click on this link
http://www.mzriders.com/viewtopic.php?t=804
ar dave
water leak 125.jpg (4.38 KiB) Viewed 6589 times
Postby herbalist » Thu Aug 11, 2005 5:32 am
firstly, thank you all for your help!!!!!!!!!!
The coolent leak seems to be stopping.
It is not the over flow hose, as I have now located that and its clean and dry.
I dont think it is the drain hole either as the coolent is dripping from the very top of the engine.
(ok sorry for the bad terms..... If you look on the left side of the bike at the top part of the motor there is a peice of metal with two hoses attatched. (ones about 2" the other 1 1/2"
One runs straight up and the other runs back towards the exhuse.
It seems to be coming fromto the hose that runs virtically straight up.
It has pretty much stopped by itself now.
Im still keeping an eye on it.
Will prob take bake to the show anyhow, just to be on the safe side.
herbalist
Postby jbthumper » Thu Aug 11, 2005 7:37 am
ok...that's a bit of relief.... :)
it's just a loose hose clamp then...
p/s:i took the easy way out by replacing mine with normal hose clamp...
but you'll lose the "bling" factor....haha..
:smt033
jbthumper
Re: water leak
Postby herbalist » Sun Aug 21, 2005 9:23 am
DAVID THOMPSON wrote:see picture below
ar dave
Firstly thanks for all the help....
Took my bike to the shop yesterday.
And they still have not fixed the leak. :-(
And now I have drips of petrol near location 2 on your pic......
What should I do now??????
ANY HELP PLEASE!
herbalist
Postby jbthumper » Tue Aug 23, 2005 1:42 am
are you sure it's petrol??how did it get up the??? :shock:
BUT if it's the engine oil...just tighten those screws on the head cover..(not too tight,though)
for the coolant problem,tell them to check ALL of the hoses....including the small one which links the two piece radiator together...most likely it's a leaky hose...
hope this helps!
:smt033
jbthumper
Postby herbalist » Tue Aug 23, 2005 3:36 am
jbthumper wrote:are you sure it's petrol??how did it get up the??? :shock:
hope this helps!
I would say your 100% right. (about the coolant)
The guys in the shop just didnt fix the leak.
I called them this morning and they slipped up by saying: -
"When youve done 500 miles and come in for your 1st service we will fix it properly then...." sugesting that they didnt "fix properly" on sat.
As for the petrol,,,, its just the dranage pipe... its a 5/10mm clear pipe that dones an S bend and catches the overflow.... and it was like half a drip (maybe not even that), and I panicked.
Every thing I know about motorbikes I have learnt in the last 3 weeks.......
its a learnng curve for me,,,,,,,,, thanks for your help.
herbalist
Postby jbthumper » Tue Aug 23, 2005 7:06 am
ok. since it's the drainage pipe...for the up coming service....ask them to reset/adjust your float in your carburetor....i had this problem when i first got the bike too... :-)
p/s:don't worry...everyone starts from scratch...but we have to start somewhere,right? :D
cheers.
:smt033
jbthumper
Return to 125 cc
Users browsing this forum: No registered users and 68 guests
