The Imgur link if you want: https://imgur.com/gallery/UiBT6B0
She runs but not fantastic. That is the easy part. Some of the electrical seems a little messed up too. Also shouldn't be too hard. The fact that it's complete more than makes up for it.
AlanJ wrote:Hi Eomund,
Sorry I am a bit late in seeing your post, just a thought, as you are taking the carb off and as you said it was not running that well, could it be that the main seals may need replacing. they do get hard through the years and as you have the carb off rest a piece of tissue paper over the manifold opening turn her over and if the tissue pulls onto the manifold then all is ok. You might well know of this, but just in case.
Safe riding when she is up and running, take care Alan.
Eomund wrote:AlanJ wrote:Hi Eomund,
I'm a bit confused by this. It's issue is electrical. Basically the spark isn't keeping up. I'm replacing the wire and cap, and for good measure I have a new coil coming as those go bad sometimes too. Overall she runs fantastic. It's when she gets warmed up, the spark isn't working as well. And the plug wire is craaaaaaaaap. I'm honestly stunned it works with how bad of shape it's in. I have the parts coming and she will be premo.
