Single carb on Mastiff AGAIN!
Re: Single carb on Mastiff AGAIN!
Postby Puffs » Sun Apr 05, 2020 8:19 am
Congrats!
Do you really need to remove the air box?
I have an SP400 and the previous owner removed the air box to fit a silly K&N, and I deeply regret he did that.
At any rate, make sure your jetting is OK.
Postby breakwellmz » Sun Apr 05, 2020 1:57 pm
Hi.
Only in order to modify it to fit an appropriate air filter.
Postby breakwellmz » Mon Apr 20, 2020 2:40 pm
A mate turned up an adaptor to match my K n N filter to the carb for the price of a packet of fags and i put in the three attachment holes.
Pulled out the vent passage cap on the side, tapped it M8, and screwed in a modified brake bleed nipple to which a rubber pipe is pushed on to.
Rusty enrichener cable is only a temporary one!
Air box modified and now await a 60mm ID silicon coupling hose -
Postby Puffs » Tue Apr 21, 2020 4:11 am
Yes, mods to that airbox are in order.
Not a fan of K&N, as you may have seen elsewhere, but with proper jetting it'll do on a 4T.
Edit: correction - I actually fitted a K&N filter on my Ducati. Of course there the ECU takes care of any mixture/jetting issues.
Postby breakwellmz » Tue Apr 21, 2020 7:28 am
Hi.
It makes me wonder how it used to breathe at all to be honest, just between the top edges of the box and the underside of the seat and that (the air box)
used to have a vinyl lip filling most of that gap!
The K n N was off my old 580 BSA/CCM and it appears to be the right sort of size, i also have a bottle of K n N filter oil!
The CV40 pumper can rotate in situ for easy access to float bowl and slide needle for jetting changes which has made me go ahead with fitting an alternative exhaust system as well.
Cheers
Postby Puffs » Wed Apr 22, 2020 6:33 am
I don't know what the air box looks like on the Mastiff, but on many bikes there seems to be little breathing space between the seat & the top of the air box. But it's far away from the carb, with that volume of the air box between it, evening-out the pulsating suck-suck-suck of the engine. I guess they thought about it. Also reduces noise, as you know, an open throttle can make a bit of noise too. Hence the foam on the lid in
On the K&N on my SP400 I'm also using that blue Putoline filter oil, which gets very sticky when the solvent has evaporated. What does the official oil actually look like?
Postby breakwellmz » Thu Apr 23, 2020 1:58 am
Hi.
It`s not like trying to run up hill with your hand clamped over your mouth then? :lol:
Postby Puffs » Thu Apr 23, 2020 5:33 am
No, not this YZ. 55HP in a 96kg package (with a WR gearbox to cope w/ the difficult climbs). Juicy.
If you're talking about this type of foam filter & oil: nah, TwinAir & Putoline have been champion for many years, see fi https://www.twinair.com/world-champions-on-twin-air.php. Just count the titles.
If you're talking about putting this type of oil on a K&N: again no, the SP runs fine. Not a very fast bike, obviously, but few 40 year old bikes are.
Postby breakwellmz » Thu Apr 23, 2020 9:34 am
Hi
That looks interesting.
That double the original power output and a lot less weight, tell me more!
I had a GN400 which used the same engine. It was quite quick off the line but could be a pig to start and i soon wanted to go round corners faster that it did!
So why did Suzuki drop it and replace it with another (slightly smaller) air cooled single in the DR350?
Postby Puffs » Fri Apr 24, 2020 8:03 am
No sorry if I was unclear. The pic above the SP is an oiled TwinAir filter in it's airbox, in a YZ250. That too breaths below the seat, like your Mastiff. It has standard 55HP & weighs 96kg dry. Maybe a bit more now, as it has a bigger tank, lights & a different rear mudguard (with a tail light), maybe now 98kg without fuel. It's a different bike from the SP400 pictured above.
That SP400 has a bog standard engine, with originally 27HP, and originally weighing 127kg dry. When I got it, it wasn't quite complete, all the alu & the rear mudguard are mine. What it weighs now I wouldn't know, and I don't really care. I didn't make those things to make the bike lighter, just because I did not have the originals, while the steel mudguard was rotted.
Yes, the GN400 had the same engine, but quite a different seating posture & steering geometry.
The SP400 was only made in 1980, and in '81 it was succeeded by the SP500, and in '85 by the SP600. That had a totally different engine, the same unit as in the DR600. I don't know why they stopped the SP line, probably lack of sales? Superfluous? The DR line, which started simultaneously with the SP's (with the DR370 in '77), always had a stronger offroad focus, and better suspension. The DR line continued.
Apologies for the derail.
Postby breakwellmz » Sat Apr 25, 2020 12:58 am
Hi.
All clear now!
My Beta Alp 4.0 (DR350 engine) - Love it! The Mastiff may end up being lighter than the Beta!
Postby breakwellmz » Wed Apr 29, 2020 11:02 am
Well i`m so pleased with the way this runs i`m going to keep to this setup and not bother with the manifold and other inlet port, so thank`s to STANIMAL for the inspiration! viewtopic.php?f=3&t=7357
It`s more prompt to start and idle (especially from cold) and power is stronger and more linear right from idle up.
There was no numbering on the pilot jet but best idle was about 2 1/2 turns out so it must be in the right ballpark.
I`ve raised the needle with one M4 washer but i think i`ll add another.
I must add that i replaced the original silencer with a regular looking, road legal silencer and baffle and opened up the airbox at the same time as fitting the carb, so i`m not exactly comparing like with like.
Postby jpmsteadi » Tue May 05, 2020 1:04 pm
It is a very interesting proposition youve done. I'm sure it runs very well at most RPMs. Id be curious to hear about how it feels right up to redline. thats the place I'm thinking this setup could be problematic. But, with the carb so close to the intake valves and with the cross over you might be getting more swirl going into the cylinder and a more responsive throttle by not having a runner. I think the best solution is to have two smaller carbs opening sequentially, but the added complexity and cost aren't worth it for me. I just got an FCR39 (https://www.keihin-na.com/aftermarket/f ... arburetor/) off of a WR450 to install on my skorpion. I am going to design an intake manifold, partly cause of the size of the carb and the fuel tank means it wont go directly onto the intake port.
I love to see people experimenting!!
jpmsteadi
Postby breakwellmz » Tue May 05, 2020 4:57 pm
Hi jpmsteadi
Well i`m very pleased and not a little surprised at how well it runs to be honest!
I`ve been up to the red line a couple of times and it doesn`t seem to be an issue despite having less overall total carb inlet area compared to what it has replaced but then it has (i feel ) a less restrictive exhaust and an opened up air filter box as i said, perhaps that compensates.
The new carb is no closer to the valves than the original ways by the way, in fact it is further away from the LH valve than original.
I do know that it suits me and the sort of roads and conditions that i ride and the throttle response is really good throughout the rev range without any downside that i have yet come across.
I started off with the intention of making up a manifold and adaptor etc to supply both inlet ports and it seems i`ve come up lucky by using a cheap and cheerful carb combined with a simple installation to get the results i wanted.
Keep us updated on your project.
Cheers
Postby jpmsteadi » Wed May 06, 2020 3:35 pm
Thats great. I'm glad to hear it is doing well. Super interesting. It makes me very excited to fit my pumper carb. The bike is already great; can't wait to see how good it is with a better carb.
jpmsteadi
Users browsing this forum: Google [Bot] and 15 guests
