TPS Issues
TPS Issues
Postby d-lane » Fri Apr 24, 2020 8:03 am
Hello, I got a 2005 MZ 1000s. Parts are extremely rear around here in the US. I finally got some of the parts I needed hand made and put on. Bike fired up a couple of times and ran awesome. Long story short, I cranked it the 2 days ago and the bike instantly jumped to 9k rpms while idling. I thought maybe the throttle cable was stuck, but after quick examination of it, nothing seems to be out of the ordinary. Only thing I can come up with is that I have a faulty TPS sensor. Has anyone on here found a site that still sells or makes parts for this bike?? Any help would be greatly appreciated!!!!
d-lane
Re: TPS Issues
Postby DAVID THOMPSON » Fri Apr 24, 2020 5:02 pm
https://www.muz.de/
Re: TPS Issues
Postby Thorsten-aus-SO » Fri Apr 24, 2020 5:11 pm
Hi.
Most parts are available in Germany.
Check out https://www.muz.de/ or ask in the german forum http://mz1000.motomonster.de/
Ask in your language. No problem.
Thorsten-aus-SO
Re: TPS Issues
Postby d-lane » Sat Apr 25, 2020 1:38 pm
awesome, thanks for your help!
d-lane
Re: TPS Issues
Postby silver MZ-1000s » Tue Apr 28, 2020 11:58 pm
Hi , did you scan the codes ? Are you sure it’s a TPS ? Did you check your low RPM air acuttator motor ? The one on your air filter box where two hoses from your throthle bodies come to , its on same side as your TPS sensor on the bottom of the air box . If it would be it it think 2nd gen aprilia got something simular , good luck .
silver MZ-1000s
Re: TPS Issues
Postby silver MZ-1000s » Wed Apr 29, 2020 12:04 am
BTW , i don’t think TPS will cause your motor to rev that hi , check for air leaks , check your throthle body hoses . :D
silver MZ-1000s
Return to 1000S
