Mastiff choke
Mastiff choke
Postby Whitey » Sat Jun 13, 2020 11:05 am
Hi was wondering if it was possible to modify the standard cable choke and make it a push pull type no cable .
Whitey
Re: Mastiff choke
Postby Puffs » Sun Jun 14, 2020 3:00 am
Yes. With a construction like in a small toggle clamp, pulling where the cable pulls: Image
Or maybe just use a lighter spring & friction, as done in other carbs.
Re: Mastiff choke
Postby breakwellmz » Sun Jun 14, 2020 4:24 am
Whitey wrote:Hi was wondering if it was possible to modify the standard cable choke and make it a push pull type no cable .
You can buy these generic ones easily enough. (I`m not saying this particular one fits) or modify you current one by having a loop of cable to pull on.
Re: Mastiff choke
Postby Puffs » Mon Jun 15, 2020 3:37 am
Yes you pull the cable to choke, but then choke has to stay on, without pulling - until you push it back. If you want that, I think you need some trickery. Ah well, maybe not on that carb.
Re: Mastiff choke
Postby breakwellmz » Mon Jun 15, 2020 7:01 am
Hi.
Mine doesn`t need to stay on once started ( it is the modern equivalent of a tickler after all rather than a true choke and pretty crude with it!)
All of the generic ones i`ve seen have a two-position notched rod that will keep it in place, and they have all been the same piston diameter!
I`ll take a look at what i`ve got and get back to you if you wish.
Cheers.
I forgot to add this last time -
https://www.ebay.co.uk/itm/Carburetor-P ... 4902.l9144
Re: Mastiff choke
Postby Whitey » Tue Jun 16, 2020 1:21 pm
Cheers bud had a look at these on ebay ,do you know if one in link fits the mastiff / baghira .
Whitey
Re: Mastiff choke
Postby breakwellmz » Wed Jun 17, 2020 1:55 am
Hi.
I thought you were going to ask that! This has come up before, here - viewtopic.php?f=3&t=6201
Check this out, a list of bikes that use the same one, over to you. - https://www.partzilla.com/product/yamah ... 4371-01-00
Cheers
Users browsing this forum: Bing [Bot] and 2 guests
