parrbd wrote:
What is the reason for using C3 bearings when the engine designer specified C4? Do you think there will be some sort of improvement?
Yes parrbd, good point. Originally I was thinking along the same lines, + that they have been making engines like this, in Zschopau, since the 1920's or so. As said, at the time I did that work I never looked at any original manual, as I didn't have any. And it looks like what came out were C3's, and I just put back the same class bearings.
But see that that original German spec for the EM250 says C4f. That might be some DDR classification? I am not certain C4f is the same as what you nowadays get when you ask for a C4?
In an attempt to clarify, I had a look at the "Reparaturhandbuch MZ ETZ 125, 150 & 251.pdf", which is dated 1/07/'89, so just when the wall was about to fall. I think that's the latest official manual there is on these engines, but still in DDR times. The EM250 engine and the EM251 engine are largely the same (with some differences in the barrel). There I find:
- Technische Daten EM251.jpg (19.55 KiB) Viewed 1142 times
C46??? What is that???
They show open metal-caged bearings:
- EM251 - 6306 is open.jpg (43.65 KiB) Viewed 1142 times
But elsewhere I saw a similar plastic caged bearing as BM showed - I guess it varied with time?
And they seem to have a certain predisposition for these C4f's - they also seem to use them in the gearbox...
- EM251 - gearbox also has C4's.jpg (32.03 KiB) Viewed 1142 times
I agree with what Kruh says, and I'd put C3's, as I think I did many thousands of miles ago (something like 20k miles).
Not yet entirely satisfied, I finally had a quick glance on the German MZ forum, where I see written that:
- modern-day C3's are commonly advised for the main bearings.
- C3's should also be considered in the gearbox where the manual specifies C4f's. The extra clearance should reduce the chance of jamming.
- The C4 thing with even more clearance came from the higher production tolerances in DDR times.
- C3/4/4f has nothing to do with the cage type, and yes, plastic cages were sometimes used. They are supposedly equivalent to open metal cages.
- the 'f' addition may have something to do with being a low-noise bearing. In DDR times.
