Yamaha R6 calipers on a Mastif
Postby Whitey » Fri Jun 19, 2020 1:26 pm
Want to replace my brake calipers on my mastif,heard yamaha R6 ones fit ,anybody done this and can give me imformation on year of R6 ,thanks in advance .
Whitey
Re: Yamaha R6 calipers on a Mastif
Postby handsomejackuk » Fri Jun 19, 2020 2:25 pm
i got an r1 disk on mine that fitted straight on as my original fell apart and locked up the front end best modfication i ever made...
not sure about the caliper though... i have some trx850 front calipers here i may try to see if they fit but not much point as mine works ok...
handsomejackuk
Postby dylan22 » Fri Jul 23, 2021 10:03 am
My 2019 edition has 4-pot callipers. Also, the new Yamaha R6 model has the same setup with radially mounted callipers. According to the mototechindia specs sheet, the latest Yamaha R6 comes with a dual 320mm opposed piston calliper disc at the front and a single 220 mm disc at the rear. It gets 2-channel ABS but I am not sure if it comes with disable option for the rear wheels.
dylan22
Postby ralf » Thu Jul 29, 2021 12:02 pm
You may have already considered this but beware, calipers and master cylinders need to be matched or you might run out of lever travel or find the new combination very wooden or very sharp! It's not rocket science but needs a bit of thought.
ralf
Users browsing this forum: Google [Bot] and 59 guests
