breakwellmz wrote:Hi Puffs.
I don`t see the inlet manifold seeing enough variation in temperature to worry about the bond failing personally, its always got a cooling charge running inside, it could get pretty hot after shutdown i suppose.
I offered the Grizzly manifold up to head on the Mastiff earlier. I`ve decided there just isn`t the space to utilise it within the frame with where the carb should be, there is SO much more room on the Skorpion.
I have been tinkering though.....
Now, what to do with that `transfer`port in the head?
An interesting idea, but I can't imagine that would flow very much air very well. No idea how it will work, but perhaps you can use some sort of bent intake tract around the frame member? I don't know the design of the Mastiff.
i
Users browsing this forum: Bing [Bot] and 35 guests
