Hand Gaurds
Hand Gaurds
Postby blackpantheruk » Fri Sep 09, 2005 7:02 am
Anyone know what hand gaurds will fit straight onto the Black Panther?
trying to find some on t'internet.
i like the gaurds that cover your whole hand and connect to the bar end,
Cheers,
Craig
blackpantheruk
Postby BRAAAP ! » Fri Sep 09, 2005 1:02 pm
I've just bought some of eBay. .
check out item #4574270178 on ebay.co.uk
cheap end of the market but don't look like a pair of moose ears !
not fitted mine yet but dusne look to difficult . . . .
two wheels good, four wheels bad. . . .
BRAAAP !
Postby roge-a-billy » Fri Sep 09, 2005 4:03 pm
Got some to of Evil bay. I'm going to have to either buy shorter / different levers or cut the ends off and get replacement ones to fit for M.O.T time. Also crash bungs for the wheel spindles, the spindles seem to be solid right the way through, so will have to put a thread in them with long bolts :roll:
roge-a-billy
Postby BRAAAP ! » Fri Sep 09, 2005 4:21 pm
going to get my MOT before fitting them. . .
seen a lot of folks that seem to angle the guards down to avoid this problem. . .
anyone got any ideas regarding fitting brush guards ???
:smt102
BRAAAP !
Postby phlat65 » Fri Sep 09, 2005 8:30 pm
trimming the levers, or wider bars so you can move the clutch and brake in to clear. I run bark busters on the RM , and never have to cut levers, but on the baggy, I had to remove 1 inch or so.
I run the MSR guards, and they have lived through an asphalt crash with minor scratching.
Postby bigzed » Sat Sep 10, 2005 3:31 am
I'm using acerbis guards,not the bark buster ones though, which went straight on to renthal bars with no cutting of levers or messing about.
bigzed
Postby blackpantheruk » Sat Sep 10, 2005 6:16 am
where do i get renthal bars? are these better than the stock?
Cheers,
blackpantheruk
Postby bigzed » Sat Sep 10, 2005 10:51 am
Hi craig,Try bandcexpress , demon tweeks or google for a local dealer, i don't know if they're any better than stock but hey bling is bling
bigzed
Postby blackpantheruk » Sat Sep 10, 2005 10:58 am
what size do i get?
cheers
blackpantheruk
Postby bigzed » Sat Sep 10, 2005 2:02 pm
http://www.bandcexpress.co.uk/cgi-bin/b ... FROAD&nav={universal}
Hi,i would say any of the top two, although others here might be able to suggest otherwise through experience with different types.
aw the best
Gaz
bigzed
Postby bigzed » Sat Sep 10, 2005 2:03 pm
aw the best
Gaz
bigzed
Postby phlat65 » Sat Sep 10, 2005 9:25 pm
size and bend are all preference. the CR high, and CR low are the 2 most common bends. I think I run a doug henry bend pro-taper, they are pretty straight with little pull back.
Users browsing this forum: Bing [Bot] and 39 guests
