My mastiff is leaking coolant out of the weephole.
Is this what I need to get?
https://www.off-the-road.de/en/XT-660Z- ... T-660.html
breakwellmz wrote:Hi.
That kit is for the later fuel injected, four-valve engine and is probably too comprehensive(And expensive!) for your needs.
Start with just replacing the outer pump seal first. I`ve done this on other engines (easy to do and sorted the same problem you have) but i don`t know the one you need for our engine, check out a Yamaha parts fiche.
