Anyone know anything about coils???
Postby JawasandMZs » Thu Apr 29, 2021 2:20 pm
I think I've damaged the coil on my ts 150 (which is converted to Vape) by touching the live AC wire against a wire that goes in. It works but fails under load. I have found an exact replacement on ebay but it's a HUNDRED QUID!!!
Would any 12v coil work? Or even a bog standard etz coil from my spares box?
The original fault, now resolved I think, was caused by the person who installed the vape who used the indicator relay as the ignition relay rather than the proper relay that was provided with the kit. Im now working with a manual kill switch.
Please help!
Thanks for the answers!
Vape strongly go outta their way to stress that their gear is mega reliable so who else can i blame?
JawasandMZs
Re: Anyone know anything about coils???
Postby DAVID THOMPSON » Thu Apr 29, 2021 3:31 pm
i have heard all the stories years ago they just get worse...
and i am getting to old to fix some thing i have never seen in person
and the wiring drawing does not match
dave :?: :smt021
Postby mr_luke » Fri Apr 30, 2021 1:45 am
Sadly, you won't be able to just use any old coil with the Vape system, as their coil has the CDI unit built in. It should be possible to find a compatible replacement, though. I am sure I have read elsewhere that one of these will work. I have been meaning to buy one to keep on the shelf as a spare, so I'd be interested to hear how you get on!
Alternatively, it should be possible to use a separate AC CDI and coil setup, available even cheaper from ebay, but I don't know if these have been tried with the Vape system yet.
mr_luke
Postby Puffs » Fri Apr 30, 2021 4:22 am
Postby Gerryman Ts125 » Fri Apr 30, 2021 6:03 pm
I thought any single/double 12v coil would work. I. E any coil at all, they all input at the switch side (low voltage) 12v through a single connector and give out (bang side) thousands of amps across the sparkplug gap. Most of them (in my opinion also work with some car Cdi's) are compatible with each other.
Only way to find out is to try. As they're all 12v positive or negative earth.As I have a box filled with Kawasaki Ar125 12v coils and some are also Yamaha, Honda, Suzuki, and Italian 50-100cc Itchiefany's. And they all worked with my countless single cylinder Ar's and Honda.
Gerryman Ts125
Postby mr_luke » Sat May 01, 2021 5:08 am
The trouble is that the Vape system has the coil and CDI box potted into the same unit, so if you just replaced it with a 'normal' coil you'd have half the ignition system missing!
mr_luke
Postby Gerryman Ts125 » Sat May 01, 2021 5:43 pm
The original 60w dynamo/contact breaker system was as basic as you got. The Vape gives you, contactless ignition timing and 160-180w three phase altenator (even so, how much power does a small Mz motorbike use, not much more than 95w) And 12v of course. A coil is still a coil, even if its shape is strange. They normally have one or two wires going in.. One pos 12v power one, one switched neg one. And not forgetting the high tension thick black one to the plug. Still not very complicated as ignition systems go.
Gerryman Ts125
Postby Guesi » Sat May 01, 2021 11:31 pm
As it is mentioned above, the Vape coil has the CDI parts inside.
So there is no way that a normal iginition coil will work on a vape system.
You have to replace it with a Vape ignition coil.
@gerryman : We all know how an ignition coil looks. But the thread was about a Vape system......
Guesi Motorradteile
MZ spare parts
Postby JawasandMZs » Sun May 02, 2021 3:19 am
Thanks all for your responses. Have gone for a pattern coil designed for the MZ Simson which looks virtually the same as the one for the TS 150. Just £14 as opposed to over a hundred!
Will let you nice people how I get on and so add a bit to our knowledge bank:)
JawasandMZs
Postby Puffs » Sun May 02, 2021 5:18 am
Postby Puffs » Mon May 03, 2021 3:23 am
Postby mr_luke » Mon May 03, 2021 7:11 am
That looks like it could be a very useful link. Thanks, Puffs!
mr_luke
Postby Blurredman » Tue May 04, 2021 6:12 am
I'm sorry Tom. My wiring ability wouldn't be able to fix a coil :( From what i've read they're intermixed with different cababilities (ie cdi/coil) so I'm not sure if it's a case of just putting another coil on unless it was an replacement from the original provider...
Though, others here seem to have have good ideas/pointers.
1987 MZ ETZ300 - 38,000 miles
Postby Gerryman Ts125 » Tue May 04, 2021 11:11 am
Meh, the advert does say "Ignition coil", not cdi and coil combined" cannot blame anyone for false advertising. And pray tell, even though most Mzs don`t have something as simple as a advance/retard system how do they work goin up hill. :roll: The vape uses the exact same crank position sender (but transistorized) how does it know? Even though I do have a circuit tester and a multimeter in my garage, But sometimes helping people has to many cooks ruining the same broth. :lol:
Gerryman Ts125
Postby Puffs » Wed May 05, 2021 4:33 am
Users browsing this forum: No registered users and 77 guests
