Gerryman Ts125 wrote:First obvious point! have you contacted the seller? What did they say? Can they shine any other light on your problems. You seemed to have ruled out most of the mechanical problems (apart from how does it look when you run it with the points cover off) My TS 125 - 150's all did what your saying. My problem was traced to the bolt that holds on the cam, that the mechanical points ran off was slack/worn.
And the charging system was shot.
Puffs wrote:Ta for the pic of your very yummy bike in the other thread!
Yes the issues can be related: the clutch side crank seal may have been pushed out, causing a sudden poor performance, and pressure in the gearbox causing the oil leaks. Is the plug wet with oil? Smoke? Smell of the smoke? If that seal is out, I'm actually surprised it would still run... But maybe just a lip tore off, or the integrity of that seal got compromised some other way. But that seal might well be it.
Other than that, in the summary you say "complete ignition system has been replaced", but have you replaced the coil? That too might be a cause for these sort of symptoms.
Guesi wrote:Did you change the oil seals on the crankshaft ?
AlanJ wrote:Hi Bob,
Great pic, sad to hear of your problem, but, I must agree with Puffs and Guesi about the main seals because the seal on the left side could allow pressure on the gearbox and therefore causing your pressure problem. before you do anything else, take the carb off and place a tissue over the manifold opening, and
on kicking it over the tissue should be sucked to the surface, but, if not, then you have a seal problem. Just for your info, my 77 250/1 TS, on the clutch side
lhs, had the original seals and they failed by shrinking in the housing and of course allowing pressure in the gearbox and oil into the crankcase. You don't
have to split the crankcase on the 250/1 but I have a feeling you will have to on your 150, anyway Guesi will put you right on this I feel sure.
Take care and safe riding. Alan.
ScotBob wrote:Some pics:
Users browsing this forum: Google [Bot] and 11 guests
