by MZFred » Sun Jan 23, 2022 6:59 am
Hi and good day, has any one fitted a Dellorto Carburettor to the above please as the old original one is getting tired and looking for alternative to the Mikuni conversion?
MZFred
by Puffs » Mon Jan 24, 2022 4:20 am
Hi MZFred, what model do you think of, and what would you hope to gain by using a Dell'Orto?
Just wondering. If the carb body is worn, replacing it makes sense, but I'm not sure there is much to be gained by using another brand of carb. Or is there?
(I used Dell'Orto carbs in the past, though not on an MZ; they are good quality IMO.)
- Moderator
by MZFred » Mon Jan 24, 2022 4:43 am
Thanks for your comment Puffs, like many in the uk with bikes that have done good mileage the original carbs are getting worn out and good original one are hard to find. The most common replacement are Mikuni and these are available but at a premium price, however new Delorto carburetors are ready available at a good price and used by many in the scooter world on their 2 stroke singles, therefore my original question.
MZFred
by Kruh » Mon Jan 24, 2022 5:44 am
Haven't seen many. But there is no reason it wouldn't work well. Dellorto makes great carbs. I'd say its a good alternative.
Any modern carb should outperform the original. But differences beetwen brands likely won't be noticable. As with any carb conversion, there is no formula, a set of pilot, main jets and a lot of trial and error is neccesary.
Kruh
by MZFred » Mon Jan 24, 2022 7:39 am
So following on this topic what other carburettors have MZeders used on the above bike with good results.
MZFred
by Puffs » Tue Jan 25, 2022 7:27 am
Puffs on Mon Jan 06, 2025 10:38 am, edited 3 times in total.
- Moderator
by MZFred » Tue Jan 25, 2022 9:10 am
Thanks for the reply Puffs any info re the 30mm PWK model and jets etc please.
MZFred
by Puffs » Wed Jan 26, 2022 5:22 am
Puffs on Mon Jan 06, 2025 10:43 am, edited 2 times in total.
- Moderator
by MZFred » Thu Jan 27, 2022 11:23 am
Many thanks for the useful information, I will try one of the carbs/setting as you have recommended !
MZFred
