Slow starting.
Slow starting.
Postby Edge76 » Sun Mar 13, 2022 1:52 am
Hi all my new to me Scorpion tour. Runs great but if I leave her for a week or so takes 15-20 cranks to start her. Any ideas what might be causing it.
Regards Edge
Edge76
Re: Slow starting.
Postby lavrentyuk » Sun Mar 13, 2022 12:02 pm
Try draining the petrol in the float bowl off - there is a screw for that very purpose. Please be careful with it as they seem to round off easily. Try a JIS driver in the appropriate size, they do better.
For some reason they don't seem to like fuel thats been sitting in the Carb, no idea why.
Richard Marshall
Wales, U.K.
lavrentyuk
Re: Slow starting.
Postby Puffs » Mon Mar 14, 2022 5:29 am
Re: Slow starting.
Postby Edge76 » Mon Mar 14, 2022 4:03 pm
Thanks for the info guys. Will I've it a go.
Edge76
Re: Slow starting.
Postby dickl » Tue Mar 15, 2022 5:16 am
Try and find out how far you can travel after switching the fuel off. Then when you are nearing the end of a run switch the fuel off at this distance from the end. This should leave you with no or very little fuel in the carb. I do this and the bike starts very easily. Hope it works for you!
dickl
Re: Slow starting.
Postby jfh » Tue Mar 15, 2022 11:23 am
I use the same technique as Dicki and it seems to work well. It’s also a good idea if you have a bike you rarely ride, keeps the carbs from getting gummed up.
jfh
Re: Slow starting.
Postby MarkyMuZ » Tue Mar 15, 2022 3:57 pm
I have suffered this same issue, in additional to previous comments (to which i have tried and still consider doing myself). I tried somthing different after destroying another battery and still having a to do alot of cranking to start even with a new battery. I decided to to clean the connections on the starter solenoid, even though they looked clean, i still cleaned them with sandpaper along with other connections for the start motor.
Reason being that if the connections are dirty they pull the volts down when cranking taking it away from the coil, thus giving a weak spark.
Having done this on my bike is alot easier to start.
Its worth doing just as maintence activity, clean the connection, and put some greaase on to help stop them oxidising.
Ta.
MarkyMuZ
Re: Slow starting.
Postby ralf » Thu Mar 24, 2022 12:27 pm
I have similar experiences to the other contributers. I turn off the petrol about 1/4 mile from home and then let it idle until it stalls on the drive. Starts no problem next time. Another point not mentioned, I've bypassed the fuel pump and piped the tank direct to the carb. The pump is an unnecessary complication.
ralf
Re: Slow starting.
Postby Puffs » Fri Mar 25, 2022 4:27 am
Users browsing this forum: No registered users and 47 guests
