New TS250 Owner
Re: New TS250 Owner
Postby Prusakowski-Ost » Sat Feb 12, 2022 5:18 pm
Thank you for your assistance!
Prusakowski-Ost
Re: New TS250 Owner
Postby Puffs » Sun Feb 13, 2022 4:45 am
Re: New TS250 Owner
Postby Guesi » Sun Feb 13, 2022 9:48 am
Hello.
The engine has to be taken apart for changing the seals.
When you did that, I would suggest to also change the bearings.They might be rusty due to the long storage....
And the oil draining can be caused by the damaged oil seald. The pressure from the crankcase can be pressed through the damaged seals into the left side of the engine (where the clutch is located (producing an over-pressure there).
This overpressure causes the the oil to drop out of the engine....
Guesi Motorradteile
MZ spare parts
Re: New TS250 Owner
Postby Puffs » Mon Feb 14, 2022 5:35 am
Re: New TS250 Owner
Postby Guesi » Mon Feb 14, 2022 6:39 am
In the end, it doesn´t matter where the oil comes from, because , as you said, the engine has to be regenerated .
Guesi Motorradteile
MZ spare parts
Re: New TS250 Owner
Postby Puffs » Tue Feb 22, 2022 4:22 am
Re: New TS250 Owner
Postby Prusakowski-Ost » Sat Mar 19, 2022 6:15 pm
Sorry for the delay and many thanks for all responses! I took the head off and cleaned everything up....not much carbon after only 1000 miles. Didn't notice any blow-by from the head gasket...cleaned everything up and used the spray copper gasket sealant to ensure a good seal. No love trying to start it....back fired a few times and refused to start. The bike will be a static display for a while until I want to delve into it more.
Prusakowski-Ost
Re: New TS250 Owner
Postby Puffs » Sun Mar 20, 2022 4:55 am
Re: New TS250 Owner
Postby Prusakowski-Ost » Sun Mar 20, 2022 3:45 pm
Yes...jug / barrel came off....rings inspected...no issues. I believe you are correct....crankshaft seal failure as a cause!
Prusakowski-Ost
Re: New TS250 Owner
Postby Puffs » Wed Mar 30, 2022 5:23 am
Well, maybe count yourself lucky. Replacing seals (+ main bearings?!) is cheap, compared to a ruined cylinder, which could very well have the same symptoms.
Re: New TS250 Owner
Postby dave47 » Fri Apr 01, 2022 6:50 am
Commiserations. Any idea of the cause?
dave47
Re: New TS250 Owner
Postby Puffs » Fri Apr 01, 2022 7:45 am
Re: New TS250 Owner
Postby Prusakowski-Ost » Tue Apr 12, 2022 3:35 pm
Puffs....collect new seals and come to the U.S. to assist in getting this bike running again...... :lol:
Prusakowski-Ost
Re: New TS250 Owner
Postby Blurredman » Wed Apr 13, 2022 3:05 am
I'm sure he would (I would too) if you paid the air fare... :lol: :lol: :lol:
Re: New TS250 Owner
Postby Puffs » Wed Apr 13, 2022 4:02 am
