by smellybeard » Fri May 20, 2022 1:08 pm
I've been chipping away at my barnfind TS250. Current job is to replace the chain and sprockets and clean up everything around the swingarm.
I have the rear sprocket/chain case off and the surface is scruffy - not dirty but it looks like it. The surface has degraded a bit and it looks like the snails have given it a once over and chewed up the shiny surface.
Has anyone dealt with this successfully? What's the best approach to improving the appearance this item?
TS250/1 | Ducati 250 Mk.3 | 1960 NSU Supermax | 1946 Velocette MAC | Honda C90 | Guzzi SP1000
smellybeard
by Puffs » Sat May 21, 2022 5:20 am
Puffs on Mon Jan 06, 2025 11:07 am, edited 2 times in total.
- Moderator
by Kruh » Sat May 21, 2022 6:53 am
You could try polishing it.
I personally haven't tried the complete procedure (sanding + polishing), but I gave mine a quick polish with a good result.
Kruh
by Blurredman » Sat May 21, 2022 6:55 am
I'm not entirely sure the original casings were flat and shiney. The original ones I have had (long since replaced) do have a rough finish.. I suppose if you wanted you could just wet sand the whole thing flat and shiney
Two of my bikes have aftermarket ones, which are a flat and shiney surface. They fit and work nicely actually- though you do need to clearance a few things to make them fit nicely.
by Puffs » Sun May 29, 2022 4:29 am
- Moderator
by smellybeard » Fri Jun 17, 2022 9:31 am
I tried a clean up and a coat of satin lacquer but I'm not really that happy. It'll do for now.
Struggling to get those gummi hosen on just now.
smellybeard
Users browsing this forum: Bing [Bot] and 19 guests
