Guesi, In the post I already mention that I knew the seal was on the 'wrong way' (according to MZ gods), and one reason for replacement was the scorch marks on the seal (and melted plastic cage on clutch carrier bearing), and thought it would be a good time to install a new one with the MZ orientation.
I won't go into the seal orientation discussion myself much here, let it be said though that I did 7k miles with the seal outter face towards the clutch as in the pictures. Up until I replaced some components in the area only recently I saw no problems here. The only thing I would like to comment about the seal is... Does it
have to be an R23.. Would not an R21 suffice?? And if not, why? The secondary lip seems a bit negligible here as it's quite a bit smaller and thinner than the primary lip...
It's true, it could be a small end is at fault here with providing the metal shavings, and I suppose it's a possibility some got in the main bearing and seized it and that resulted in the crankshaft spinning within the inner race of the bearing (although the bearing seems clear to move now with no resistence, at least from this slow speed). At this moment in time that is the only reason I think these two problems (crankshaft loose in the bearing) and the metal have in common and how this has developed. It must be said that the engine sounds completely normal before I took the clutch off. I would have had no idea this was a potential failure in the making if I didn't have clutch issues.
Dave47- I'm not sure whether these are C3 or C4 bearings from memory. I do believe I bought them from Ost2rad. Actually they are SNH which although is a brand I never heard of, I don't think the bearing itself is the failure here. You're right though C4 is stated in the ETZ250 factory service manual.
Actually yes,
this is the kit I bought at the time:
https://www.ost2rad.com/MZ-Spare-Parts/ ... Z-250.htmlAdditionally with this small end bearing:
https://www.ost2rad.com/MZ-Spare-Parts/ ... Z-250.htmlBut the C3 vs C4 discussion has been well discussed before as per thread:
https://wew.mzriders.com/viewtopic.php?p=52036The bearing set had a mix I think- i'd have to check on the bearing itself when it comes out as to whether it is c3 or c4. That said, I'm not sure if it really makes a difference. After all this time, I don't think the bearing itself is to blame. The metal fragments are. As far as we can speculate at the minute with the engine still assembled, it seems the fault here (and potentially the blame for the loose bearing) is either the big end or the little end. The crankshaft
was rebuilt and balanced by Burwins at the time, and when I re-built the engine last the bearing certainly wasn't loose around the crankshaft pin. That would have definitely had me thinking red flag. I think i've just been lucky that the bearings always stayed with the crankcases in 4x engine re-builds now. But yes, the crankshafts themselves certainly did not simply drop out without a lot of persuasion, in all cases.
As for the clutch and the washers, they were in correct orientation and order- I always double and triple check those!
I'm not actually even sure when I'm going to get around to taking this engine apart.. I'm a busy man.. Obviously we can all discuss this topic in the meantime, but with 8 vehicles I have a lot to do without a little discovery like this turning up. The bike is in the corner of the garage for now until I find the energy and time to look at it bearing in mind I have other 'work in progress' situations. You'll have likely seen my other threads.. But please carry on the discussion i'd be interested in your replies regardless!
Additionally, it's worth mentioning that MZ do have a special tool for installing the RHS seal... In two parts it is a special punch and a sleeve.
https://youtu.be/6ptXHE2i0x0?t=2599
