stevebod wrote:Thanks for the continued help.
The other issue I haven't asked about yet is the clutch which is dragging quite badly.
I've made all the necessary adjustments - I even tried eliminating the free travel to maximise the clutch throw, but of course won't ride it like this, it was just to prove a point.
Even in this setting I can't select first gear without the bike either stalling or moving off.
Can I ask if anyone knows what the clutch throw should be?
I measured 1.2mm of movement at the back of the clutch actuator. Does that sound enough?
