New to this list
New to this list
Postby JulianMZRotax » Mon Nov 14, 2005 11:12 am
Hi
I am new to this list and have just bought a blue 1997 Saxon tour. It now runs fine but it has a small oil leak on the shorter oil pipe to the tank in the frame. It seems to weep where the pipe goes into the enging. The other point is are there tyres that are lower? ( Not being that tall @ 5' 3") The rear tyre is a Michelin 350/16 M45. The front is a Vee Rubber 300/18.
Thanks for your help
Julian
London UK
MZ 1997 Saxon Tour ETZ 250 1987. Motor Morini 1976
JulianMZRotax
oil leaks
Postby DAVID THOMPSON » Mon Nov 14, 2005 11:50 am
these engines are hard to kill but oil leaks are a problem
there is a oil change how to in the web site some where
when you do that you can try some sealer on the oil line
ar dave
ps i find mine runs better with spark plug ngk dpr8ea-9
it idles much better
