Blurredman wrote:Hi Pete,
Matthew here...
Yes Puffs is onto a good point concerning air leaks. However your more likely than not to feel the problems of an air leak at idle and above idle. Giving symptoms of an idle that just won't stay in a single place but wander. But of course, it can also give lean conditions on low rpm high gear situations. But yes it sounds like it could be this problem.
As puffs says, spray brake cleaner or some other material around various locations such as the carburettor to inlet join, the inlet to barrel join and also the base of the barrel all around. I've had such leaks there.
I think I would work on that first, because actually I think the pilot jet and main jet although different are minimally different.
Indeed I have never actually had the TS250 - maybe one day, might be fun - but was always under the assumption 30n2-5 is on ETZs. I don't know about any crossover period though.
I think the cutouts in the slide are all the same in design, but the valve opening of 5mm or 6mm (I don't take notice of this, I just get the bike to idle where I want it) merely identifies the gap opening in height for idle purposes I suppose.
That said- where do you live? Just curious if you're anywhere near where I could help directly maybe.
But also, did you look into the spark plug lead resistance check? It may not be the carburettor configuration, or air leaks at all!
And yes, check timing.
Users browsing this forum: Google [Bot] and 51 guests
