Removal of rubber protective cap
Postby Rob NL » Wed Jan 24, 2024 3:31 pm
How dow I remove the rubber protective cap from the speedometer?
Just pull as hard as I can? I don't want to damage anything and it needs to go back on it as well.
(after replacing the bulbs)
This thing:
Rob NL
Re: Removal of rubber protective cap
Postby DAVID THOMPSON » Thu Jan 25, 2024 12:58 am
SAND AND WHITTLE TO A THIN EDGE ON ICE CREAM STICK AND USE IT A PRY STICK
DO NOT GIT WILD WITH IT TWIST AND PRY THE RUBBER IS USUALLY STUCK
Postby Rob NL » Fri Jan 26, 2024 5:53 am
THANK YOU FOR YOUR ANSWER.
SOMETHING SAYS TO ME IT'S NOT GOING TO BE A WALK IN THE PARK TO GET THEM OFF AND TO GET THEM ON IT AGAIN... :evil:
Rob NL
Postby Jay Bee » Fri Jan 26, 2024 8:17 am
Use some lubricant - rubber grease/KY jelly ? - whatever you have to hand.
You may find it helps to remove the bottom clip and push upwards on the drive cable at the same time as pulling from the top.
HTH
Jay Bee
Postby Blurredman » Fri Feb 02, 2024 9:02 am
To remove the rubber from the clock mount, you must first remove the clock. Pull up on the clock bezel with one hand, and push up on the cable from below at the same time with the other hand. The clocks can be very tough to remove sometimes.
1987 MZ ETZ300 - 40,000 miles
Postby Rob NL » Sun Feb 04, 2024 9:25 am
Thanks all!
Rob NL
Users browsing this forum: Bing [Bot] and 28 guests
