electrics
Postby BRAAAP ! » Sat Dec 17, 2005 2:18 am
I have sorted the Baggy !, & after reading your comments this sounds like a common fault . . .
The problem is where the ignition switch connects to the loom. The red wire has corroded in the multi block connector. . .
Word to you all out there, find this connector and drown it in vaseline (petroleum jelly) :shock:
Cheers Guys !
:smt023
two wheels good, four wheels bad. . . .
BRAAAP !
Postby keithcross » Sat Dec 17, 2005 2:49 am
Just sorted another problem with my electrics. A car driver, completly out of character, followed me for about 3 miles and when I stopped he told me my rea light was out. What a nice guy.
Looked at bike when I got home and found that there was no electrical feed to the side lamp circuit. There was however power comming out of the headlamp switch. Put a tempoary feed from the connector for the light switch to the front side lamp wiring for now to get the lights working.
I will let you know when I find where the fault is.
It would seem the electrical wiring on these bikes is not the best.
wires
Postby DAVID THOMPSON » Sat Dec 17, 2005 11:41 am
when i bought the rt125 in 2002 i inspected the whole bike
and found that the wire harness was routed wrong in several places
the wires to the rear turn signals were ran in a path that had them
as tight as the strings on a banjo it took me almost a hole day to
get thing to where i was happy with the wire harness
most of the plastic tie wraps were replaced as they were so tight
i was sure they would cut the wires
i have lost 1 voltage reg. 1starter relay..... oem battery was junk
replaced first week i owned the bike
and the small wires from battery into the bike died at the first plug
in the loom plug X16b where it goes to voltage reg...
Previous
Users browsing this forum: Bing [Bot] and 11 guests
