Mastiff - coolant change precedure?
Postby andyw » Wed Mar 15, 2006 7:28 pm
Anyone help me out and give me a blow by blow description of the routine for the Mastiff please?
What AntiFreeze/Coolant is recommended or do you use?
Andy
2005 R1200GS - 2002 MZ Mastiff: No more :-(
http://www.MotorcycleInfo.co.uk
andyw
Postby phlat65 » Wed Mar 15, 2006 11:10 pm
remove the cap, remove the drain bolt on the water pump (only hex head bolt on the WP)
drain coolant into sutable container, be carefull, it will shoot out of the hole pretty far, be prpeared.
After draining is complete, replace bolt, do not over tighten, and fill with coolant slowly at the end to let all air escape. our bikes do have a thermostat (I think), so it can take awhile to fill.
I personally use the VW/Audi Longtime coolant (the Blue one)mixed at 50% with distilled water, and change it anually. you can get it at a VW or Audi dealer, I use the German brand Pentosin for all my fluids
there are many coolant formulas thee days, just stay away from the high silicate formulas. something interesting I just read, conventional coolants use silicate to lay down a corrosion protection layer, that depletes pretty quickly from the coolant, but the new mixes like dex-cool and such suspend the corrosion addatives in the coolant so they last a long time. that is why they consider them lifetime.
having worked on VW's for a lomg time, the blue coolant is the only formula that will keep a water cooled vanagon from corroding the heads at the gasket area and leaking. and it works well with aluminum engine parts.
Postby cat » Thu Mar 16, 2006 1:17 am
phlat65 wrote:there are many coolant formulas thee days, just stay away from the high silicate formulas. something interesting I just read, conventional coolants use silicate to lay down a corrosion protection layer, that depletes pretty quickly from the coolant, but the new mixes like dex-cool and such suspend the corrosion addatives in the coolant so they last a long time. that is why they consider them lifetime.
that's interesting. i don't know if the VW dealers here would have it.
anyway, yes, check the description re the formula - if they don't give any information, go to something else. i've been using MOTUL stuff, including the premixed coolant (which is not more expensive when you look at what they charge for bottles of distilled water here, and i don't have to measure it, i know theirs is right, proper deionised water. ... then there's Silkolene - that MZ recommend, and Motorex.
cat
Postby keithcross » Thu Mar 16, 2006 4:40 am
The problems with High silicate coolant is well known in another club I belong to. Silicate is basically a fine sand, this scours the inside of the water jacket. Unfortunatly it can also wear the water seal in the water pump.
Postby cat » Thu Mar 16, 2006 5:33 am
keithcross wrote:The problems with High silicate coolant is well known in another club I belong to. Silicate is basically a fine sand, this scours the inside of the water jacket. Unfortunatly it can also wear the water seal in the water pump.
oh! I never heard it that way. No wonder. Well, maybe it's not the only reason, but water pumps / water pump seals seem to be a common point of failure nowadays.
I'm going to check the MOTUL site now - seeing that I can't look at the bottle now. :-)
cat
Postby keithcross » Thu Mar 16, 2006 7:21 am
I use Silkolene Pro Cool, its works well, but is premixed and is expensive compared to other makes.
Postby andyw » Thu Mar 16, 2006 9:32 am
[quote="phlat65"]remove the cap, remove the drain bolt...........[quote]
Much appreciated and input from everyone else on coolant choice........thanks guys :smt023
andyw
Postby Fil » Fri Mar 17, 2006 4:34 am
keithcross wrote:I use Silkolene Pro Cool, its works well, but is premixed and is expensive compared to other makes.
Me too :smt023
Fil
