MZ Baghira - Technical Data, Service Specifications, Parts.
Postby cat » Thu Mar 16, 2006 2:13 am
MZ Baghira - Technical Data, Service Specifications, Alternative Parts
(Attached file.)
If anyone has any more details (like part numbers, specific models, etc.) please post them and I'll update the document.
If anyone has a problem with the html document + subfolder, tell me and I'll send you the Word .docx or add it to the .zip file.
2009-05-18
Added headlight, front brake light switch KTM part numbers.
2010-07-01
Added specs of Yamaha SZR 660 (1995) carburetor.
Added details of Yamaha SZR 660 (1995) CDI unit and ignition coil.
Changed document to html with subfolder instead of .mht so it can be opened with browsers other than IE.
2011-11-02
Various minor edits and additions.
2012-09-08
Added valve cover o-ring Yamaha part numbers.
2012-10-20
Added regulator/rectifier.
Added radiator cap.
Added front brake light switch.
2012-10-25
Added starter motor, starter relay, alternator.
Corrected regulator/rectifier from Yamaha SZR 660 to MZ 660
2012-11-04
Added to .zip file: MZ Baghira 660 - Fasteners.htm
(tightening torque and sizes)
MZ Baghira 660 - Tech Data, Specs, Parts.zip
(89.11 KiB) Downloaded 660 times
cat
Postby Hoke » Fri Mar 17, 2006 7:28 am
Greate!!!!! :D
Headligh is the same as for the Husqvarna/Husaberg to (cheaper here in Sweden) and a lot of other KTM and offroadbikes, the TTR 600 fits to (but is not H4).
The indicators are the same as some Husqvarna/Husaberg to, some mopeds have them to (then they get really cheap ;-) ).
Airfilter: KTM Duke 1 (DT1 RW 250-02) will fit ok.
Thanks 4 the greate efford, here in Sweden there is only one MZ-dealer (very good one, but far away - http://www.eurospeed.nu ) and You have to find some other bike with the same stuff on to be able to buy spare parts from the local dealer. This list is perfect for us! :D
I think that the rear breakdisk is the same as the "old" BMW 650 Funduro and the front one as the older Yamaha R6.
And off course the engine and the carb is the same as Yamaha XTZ660, so all XTZ-engineparts will fit...
Stock rear sprocket on the MZ 660 Baghira Forest (1999) = 45 tooth.
Don't forget to loosen the oilcap to before draining the oil ;-)
And then to put it on and tighten before starting the engine :lol:
Keep up the good work! :smt023
Edit:
andyw wrote:'Twin Air' filters for the MZ Mastiff,the part no you require is 154512
.......or as I did by luck find the same filter as listed for the KTM SC/Duke and Maico 98/03.
No-Toil air filter maintenance kit - aerosol bidegradable filter oil, filter grease and cleaning fluid (try MX shops :wink: )
Look here to for interchangeable parts ;-) http://www.mzriders.com/viewtopic.php?t ... changeable
Hoke
Postby cat » Fri Mar 17, 2006 9:57 am
Thanks, Hoke. The original file is from a Finnish guy's website; when I find it, I'll forward the thanks to him. :-) (His website is interesting.)
It was originally the Enduro specs (wheelbase, seat height, etc.) but I took that out before I posted it, thinking that it is not that that we are interested in; the main thing is to have a good list of alternative parts.
Hoke wrote:Headlight is the same as for the Husqvarna/Husaberg to (cheaper here in Sweden) and a lot of other KTM and offroadbikes, the TTR 600 fits to (but is not H4).
If you can get part numbers... even better. :-)
Hoke wrote:Airfilter: KTM Duke 1 (DT1 RW 250-02) will fit ok.
Is that the part number?
Good, with that and the Twin Air number that andyw has given, I should find the UNI Filter number.
Hoke wrote:I think that the rear breakdisk is the same as the "old" BMW 650 Funduro and the front one as the older Yamaha R6.
We must get part numbers, or model years. I know that 2 people used R1 front discs but I didn't add it because I think the R1 / R6 discs have changed over the years.
Hoke wrote:And of course the engine and the carb is the same as Yamaha XTZ660, so all XTZ-engineparts will fit...
Yes.
Only problem with that - for me (and the americans, I think) is that I like to get parts from US vendors because the prices are lower, but their online microfiches do not have the 660 models. (Today I was looking for the intake valve cover gasket (and I found that it was an o-ring) so I could find it only by looking at the Raptor 660.)
Hoke wrote:Stock rear sprocket on the MZ 660 Baghira Forest (1999) = 45 tooth.
Yes, sorry about that, I'll fix it.
:oops:
cat
Postby keithcross » Fri Mar 17, 2006 10:48 am
The R1 front disc I have on my Baggi is the early type, up to 2002 I think. Its also the same as the Yamaha Thunder Ace.
Indicators are also the same as fitted to some Triumphs and Ducatis. Front brake light switch same as some Aprillia's,
Most smaller o rings same as XT600,
Sprokets are the same as some model years of the XT600/TT600. I think you will find this on the site somewhere.
Postby cat » Fri Mar 17, 2006 12:03 pm
keithcross wrote:The R1 front disc I have on my Baggi is the early type, up to 2002 I think. Its also the same as the Yamaha Thunder Ace.
Thanks, Keith. I'll add the R1 disc -02. http://www.mrcycles.com has Yamaha microfiche.
Front brake light switch... that's a useful one, because they seem to be things that fail. I read somewhere that some Grimeca parts are the same as Brembo.
The indicators seem so common, and most people would probably replace with smaller ones. ...It doesn't seem worth trying to include them. I think the information in the thread is good enough.
The o-ring for the intake valve cover was $4-$5, way too much for an o-ring. Better to measure it and source it locally. I thought it was a gasket and that I'd rather have a couple of gaskets to use instead of messy Yamabond, but the o-rings will last for years.
I've just been trying to cross-reference Twin Air and Unifilter - including Uniflow / Unifilter Australia. Unifilter is hopeless and Unifilter Aus list doesn't correspond to Twin Air - the KTM LC4 models and years. Which means Twin Air get the MZ rider business. :)
cat
Postby Hoke » Fri Mar 17, 2006 12:25 pm
The front brake light switch are the same as the KTM LC4:a, and one off the two most common universals -just take the old one with you to the dealer and compare. Almost any hydraulic brakelight switch will fitt the Baggys rear brakelight to... ;-)
Sorry, no numbers :roll:
Hoke
Postby cat » Fri Mar 17, 2006 12:32 pm
Hoke wrote:The front brake light switch are the same as the KTM LC4:a, and one off the two most common universals -just take the old one with you to the dealer and compare.
ah! ok. There it is in this thread now. :-) What to do.
It sounds like they are the ones that are famous for being sh*t.
I was thinking about the tail light bulbs, that people say are blowing so much... maybe they're like the house light bulbs we get nowadays, made in China. :x
cat
Postby cat » Fri Mar 17, 2006 1:53 pm
Keith, what d'you think?
Yamaha YZF front disc part numbers (USA)
YZF-R1 (1999) 4SV-2581T-00-00
YZF-R1 (2000) 5JJ-2581T-01-00 (replaces 5JJ-2581T-00-00)
YZF-R1 (2001) 5JJ-2581T-11-00 (replaces 5JJ-2581T-10-00)
YZF-R1 (2002) 5JJ-2581T-11-00 (replaces 5JJ-2581T-10-00)
YZF-R1 (2003) 5JJ-2581T-11-00
YZF-R1 (2004) 5VY-2581T-20-00
YZF-R6 (2000) 4SV-2581T-00-00
YZF-R6 (2001) 4SV-2581T-00-00
YZF-R6 (2002) 4SV-2581T-00-00
YZF-R6 (2003) 5SL-2581T-00-00
YZF-R6 (2004) 5SL-2581T-00-00
FZ1 (2001) 5JJ-2581T-11-00 (replaces 5JJ-2581T-10-00)
FZ1 (2002) 5JJ-2581T-11-00 (replaces 5JJ-2581T-10-00)
FZ1 (2003)
FZ1 (2004) 5PX-2581T-00-00
my guess would be either the 2000 R1 or 2001-2003 R1 and FZ1/Fazer.
btw, did you use the original bolts?
cat
Postby keithcross » Fri Mar 17, 2006 3:40 pm
Yep I used the original bolts, the set up has been working well know for just about 20,000 kms :).
I also like the idea of a link that lists compatable part from alternitive sources.
JT Sprockets at denniskirk.com
Postby cat » Tue Apr 04, 2006 4:43 pm
Rear sprocket JT857.xx (where xx is number of teeth)
Listed at http://www.dennniskirk.com for Yamaha XT600
http://www.denniskirk.com/jsp/product_catalog/Product.jsp?skuId=8110340S&store=Main&catId=415&productId=o81103&leafCatId=41508
If that doesn't work or you want to see what other parts are listed for XT600, set up bikes for yourself - Yamaha XT600 1995 and 1994, under both OFFROAD and METRIC bikes. (Their system is weird; I think the JT857 sprockets were listed for XT600 under METRIC but not under OFFROAD.)
cat
Postby Hoke » Mon Oct 23, 2006 12:18 pm
Does anyone know what ignitionlock the Baghira have?
I can not read what is printed on mine after someone tried to take my bike.
On top it is printed ZADI (brand) and something like Q933?? I can only for shure read that one 9 is printed.
On the bottom it says ZADI PF385.
If it is Q933 it should be the same äs CCM 404.
The 933 (Aprillia Pegaso)/ KTM LC4 00- looks the same but have no "parkinglight" mode.
Does anyone now what the number is on the top of the lock?
Edit: In the usermanual it stand that it is Zadi Q933 :-D
Hoke
Re:
Postby pillar33 » Sat Jun 28, 2008 11:16 pm
would u hapen to have any contacts fo r any dealers or any one selling fairings for an 05 baghira
pillar33
Re:
Postby amahoser » Mon Jul 07, 2008 10:13 pm
Hoke wrote:Does anyone know what ignitionlock the Baghira have?
I know this post is old but for reference, my '99 BMW F650 (same as an Aprilla Pegaso) has the same ignition lock printed with the same Q933 that is on my Baghira. And it does have the parklight mode which I absolutley hate :D
Jose Soriano
2003 MZ Baghira
2008 Aprilia Shiver
2008 Harley Nightster
2000 Kawasaki Concours
2002 Honda XR400R
2008 Genuine Rattler 110
1974 Vespa Rally 200
1963 Vespa GL 150
amahoser
Re: MZ Baghira - Technical Data, Service Specifications, Parts.
Postby cat » Tue Jul 08, 2008 2:22 am
Thank you. :) I've updated the list.
cat
Postby amahoser » Sat Jul 12, 2008 12:56 pm
tried to download updated list, doesn't work, it opens up a IE window then hangs.
BTW, on the other interchange parts thread, (I forgot this one was around). I mentioned that I got http://www.flandersco.com to make me a set of clutch and throttle cables. They now have the templates to make up a set without the actual cables to duplicate. So you can just order them now from them.
Jose Soriano
2003 MZ Baghira
2008 Aprilia Shiver
2002 Honda XR400R
1963 Vespa GL 150
amahoser
Users browsing this forum: No registered users and 71 guests
