IGNITION LOCK, BIG PROBLEM!!!
Postby dan indian park » Mon May 22, 2006 7:42 pm
HI EVERYBODY.
Does anybody can help me? I bought my new Baghira 660 sm 1 month ago.
I did 1100 km and I just did the first check to the mechanist. He said that everything was perfect. The day after I tray to switch on the bike, but on turning the key on ignition on position nothing happened. The neutral gear lamp did'nt switched on. I try to switch off and on again, but nothing happened. One hour after i tryied again to swith on and the bike run perfect again. What do you think happened to the bike?
Dan Indian Park
dan indian park
Postby Sourcer » Mon May 22, 2006 7:53 pm
It's hard to tell. Maybe it's a ground problem. Inspect for defective cables, loose connections, corroded cable connectors or battery terminals, cracked cases or covers, loose hold-down clamps and deformed or loose terminal posts.
Sourcer
electric
Postby DAVID THOMPSON » Mon May 22, 2006 11:50 pm
double check the fuse and its holder and did the key work freely
and check the plug where the key switch plugs into rest of harness
and just look carefully at the whole wire harness
and under fuel tank as well if he had it off he may have knocked a wireing plug loose
ar dave
Postby roge-a-billy » Tue May 23, 2006 3:27 pm
check side stand cut out switch is ok
roge-a-billy
Postby tuny » Tue May 23, 2006 11:28 pm
hi, i have hade 2 mastiff's and both hade this problem, it whas a relay located behind the left rear plate, next to the cdi box, this relais is one verry special with a internal extra resistor and therfore hard to find, i made a relais with the same resistance myself and it works perfect never hade anny problems after. hope this helps you.
tuny
Users browsing this forum: Bing [Bot] and 31 guests
