Does anyone know where the Diode is physically located in the wiring loom on a Baggy?
Mine has failed leaving me without any side lights! but the park lights work, which suggests that the diode is the cause of the problem.
Tonybloke88 wrote:I found it!!
If any one else needs to find it then the diode is taped inside the loom. Its marked with a wrap of yellow tape and is half way along the top tube. When you open the loom you will see 4 grey wire comming from the front and one going from the rear all meeting inside a peice of black shrink wrap. The diode is inside the shrink wrap.
Mine had broken in half! so I routed a couple of wires back towards the air box and fitted a more robust item on spade connectors.
