mastiff choke
mastiff choke
Postby fishface » Wed Jun 07, 2006 8:00 am
Hi Guys can anyone give some advice/help on mastiff choke. Bike will not start when cold the choke is not working. I need to know how to dismantle it and how to adust the fuel mixture. If i spray the air filter with easy start it fires straight away and runs fine.
fishface
Postby keithcross » Wed Jun 07, 2006 4:06 pm
If you look on the left side of the carbs, you will see where the choke cable enters the left carb. There is a brass nut there, loosen and take this out and the cable and mechanism will come out. Clean it and replace it and all shold be fine.
Postby fishface » Thu Jun 08, 2006 3:52 am
Thanks for your advice Keith and thanks for the fork info. Checked the choke its working, need to turn the fuel mixture up any more info?
fishface
mix
Postby DAVID THOMPSON » Thu Jun 08, 2006 9:17 am
i turn the fuel /air mix wider open than stock on the rt 125
and it seems to start better warm or cold
but my friends co meter yells at me :-D
ar dave
