Diode Failure
Diode Failure
Postby Tonybloke88 » Sun May 28, 2006 4:07 am
Does anyone know where the Diode is physically located in the wiring loom on a Baggy?
Mine has failed leaving me without any side lights! but the park lights work, which suggests that the diode is the cause of the problem.
Tonybloke88
dd
Postby DAVID THOMPSON » Sun May 28, 2006 9:12 am
not sure where but the ones in my rt125 can cause you some
headaches when using a ohm /volt meter to check problems
if you do not know there in the circut
Postby Tonybloke88 » Mon May 29, 2006 3:06 am
I found it!!
If any one else needs to find it then the diode is taped inside the loom. Its marked with a wrap of yellow tape and is half way along the top tube. When you open the loom you will see 4 grey wire comming from the front and one going from the rear all meeting inside a peice of black shrink wrap. The diode is inside the shrink wrap.
Mine had broken in half! so I routed a couple of wires back towards the air box and fitted a more robust item on spade connectors.
Tonybloke88
Postby andyw » Tue May 30, 2006 3:31 am
Tonybloke88 wrote:I found it!!
Thanks for that - details of the item you fitted, where you got it etc would be good :D
2005 R1200GS - 2002 MZ Mastiff: No more :-(
http://www.MotorcycleInfo.co.uk
andyw
Diode!
Postby TrashBagh » Wed Jun 14, 2006 11:21 pm
Hey I had to replace two broken diodes in my harness. I was able to replace them with ones I got from radioshack... they only carry one diode which is rated at 3amps. Those are the ones you need
TrashBagh
Re: Diode Failure
Postby clbox » Sun Nov 22, 2009 4:39 pm
Would anyone know where the tail light / instrument light diode is located on a Skorpion Replica?
clbox
Re: Diode Failure
Postby 01deryder » Thu Dec 03, 2009 5:49 pm
I removed mine and redid the wiring through the switch on the right handlebar. Now the lights work as they should.
Cheers-olderyder
01deryder
